![]() Join Date: Feb 2016
Re: Boyds Welding Fuel Tank
So would i connect the brass fitting on the tank to the small port on the filler neck that i have shown above?
![]() Join Date: Sep 2020
That would work fine…
#4 | |
If you do that wouldn't you just be recirculating the fumes instead of venting it. I think you need to plug both holes on the top of the tank and run the vent from the bung in the filler neck into the open air through a hose. Make sure the vent hose has a couple of loops in it which will keep the smell of gas from escaping. |
#5 | |
I know the brass port is a rollover vent but should go to something Second figure is from boyds website Regarding the vent line connection Thus why im confused Last edited by Afirehawk1; 12-22-2021 at 04:47 PM. Reason: Typo |
