Old 12-22-2021, 04:33 PM   #1
forestb
forestb's Avatar
Re: Boyds Welding Fuel Tank
Originally Posted by Afirehawk1 View Post
So would i connect the brass fitting on the tank to the small port on the filler neck that i have shown above?
That doesn't sound right. Unless I misunderstood what was being said.
If you do that wouldn't you just be recirculating the fumes instead of venting it. I think you need to plug both holes on the top of the tank and run the vent from the bung in the filler neck into the open air through a hose. Make sure the vent hose has a couple of loops in it which will keep the smell of gas from escaping.
forestb is offline   Reply With Quote
Old 12-22-2021, 04:41 PM   #2
Afirehawk1
I have attached another version of the side fill tank with a secondary smaller tube next to the 2 inch. Mine is like this one without the smaller tube
I know the brass port is a rollover vent but should go to something
Second figure is from boyds website
Regarding the vent line connection
Thus why im confused
Afirehawk1 is offline   Reply With Quote
