Old 12-21-2021, 10:00 PM   #1
HOGDADDY
HOGDADDY's Avatar
Forever Sharp Horn issues
Anyone have any tips to get the horn working with this aftermarket steering wheel on my 86 Scottsdale? Thanks in advance.
HOGDADDY is offline   Reply With Quote
Old 12-22-2021, 09:03 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Forever Sharp Horn issues
Did you contact their tech line?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-22-2021, 11:52 AM   #3
HOGDADDY
HOGDADDY's Avatar
Yes no help.
Old 12-22-2021, 12:22 PM   #4
kwmech
Tell them you're sending it back and want a full refund including your shipping it back to them
Old 12-22-2021, 01:16 PM   #5
mongocanfly
Yeah..what kw said
..is there a horn button on the wheel? Or are you trying to ad one?
All a horn button does is completes the ground circuit to the horn..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-22-2021, 01:35 PM   #6
hatzie
Moderator
hatzie's Avatar
Actually it completes a ground to the coil on your horn relay.
If you ran the full amperage through the horn button it would burn it up.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-22-2021, 02:39 PM   #7
HOGDADDY
HOGDADDY's Avatar
The horn relay coil looks fine I don't why I can't get the horn to work. I don't believe the new horn button is the issue.
Old 12-22-2021, 09:03 PM   #8
kwmech
Try grounding the column with a jumper wire and see if that works
Old 12-22-2021, 09:17 PM   #9
4u2nv
I used their horn replacement kit $10 on my 87 and all went well , you using their kit ???
4u2nv is offline   Reply With Quote
Old 12-22-2021, 09:23 PM   #10
HOGDADDY
HOGDADDY's Avatar
Yes it came with the new wheel. The horn was working before I removed column, repacked bearings, new switches etc..
I did soak shift tube in Evaporust and paint it but that shouldn't make any difference.
Screw it I can live w/o the horn til I can figure it out later.
Old 12-23-2021, 12:25 AM   #11
layinrocker65
layinrocker65's Avatar
It’s pretty simple to diagnose and if you don’t believe the horn button is the issue, why are you eluding to forever sharp or their customer service being the issue?
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 12-23-2021, 04:29 AM   #12
HOGDADDY
HOGDADDY's Avatar
Because the horn was working previously so I know the horns are fine so I assumed that was the problem. When I touch both wires together I get no sound as suggested by FS so definitely not the horn button... and the fuse is good.
What would you suggest I check first?
Old 12-23-2021, 10:11 AM   #13
TKCR
TKCR's Avatar
I have the Forever Sharp wheel and horn button, all that stuff. Mine works. But that’s beside the point.
If it were me and I had this issue, I know it sounds like a lot of work, but I would take all that off and put the original parts back on and see if the horn starts working again. That’s just how I work out electrical issues, lol. I’m not the best electrical trouble shooter but it makes since to me, that if you put the old parts back on and the horn still doesn’t work, then it’s not the FS causing the issue. Something got knocked loose or cut. I know that’s not the best analogy of trouble shooting, but it’s what I would do. At least I would feel I would know what direction to go at this point.
There are also videos on changing the wheel out and it covers the horn. I watch them when I swapped mine out, because I had no clue what I was doing. So I rely on the videos to help me along on my truck.
Old 12-23-2021, 10:14 AM   #14
HOGDADDY
HOGDADDY's Avatar
I watched all the videos beforehand and after. I did everything right but something obviously is wrong.
Old 12-23-2021, 10:34 AM   #15
Greenlee
Greenlee's Avatar
Maybe check the stuff you painted and see if that created some kind of ground issue. I was pulling my hair out one time getting my tail lights working right after replacing the wood in a step side bed. It turned out that a simple ground strap from the frame to bed fixed all my problems. Somehow by replacing the wood I lost ground.
Greenlee is offline   Reply With Quote
Old 12-23-2021, 11:00 AM   #16
mongocanfly
Something somewhere, I'm assuming ,in the ground circuit isnt making contact ...if your fuse is good..
Might need to check the column plugs
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-23-2021, 11:57 AM   #17
hatzie
Moderator
hatzie's Avatar
The Horn button depends on the body of the steering column to be grounded.
The horn relay gets battery voltage all the time.
The wire from the horn button makes contact with the grounded steering column body to ground the horn relay coil. This closes the horn relay contacts to make the horn wire from the relay to the engine bay hot. This blows the horn.
Try grounding the horn terminal on the Delphi Pak Con harmonica plug on your column.
If the horn blows then your problem is in the column.
If it doesn't blow then it's time to check the horn relay, fuse, and the wiring to the engine compartment.
Painting stuff that was originally bare metal could cause electrical issues.
Old 12-23-2021, 01:24 PM   #18
HOGDADDY
HOGDADDY's Avatar
OK I believe I have it figured out and will report back when I get a chance to correct it.
Old 12-23-2021, 04:16 PM   #19
TKCR
TKCR's Avatar
Hopefully it was an easy fix
Old 01-13-2022, 07:02 PM   #20
HOGDADDY
HOGDADDY's Avatar
As promised here is the results. Firstly, I should have taken more pics on the teardown but somehow, I had installed the upper bearing in from the top when it went in the bottom side of collar.
I totally disassembled the steering column and repacked bearings. and as a bonus, installed a Borgeson intermediate steering shaft to boot.
Everything was right afterwards and yes, the horn works!
And as a bonus, installed a NEW Borgeson intermediate steering shaft to boot.
