Measurement PLEASE. K10 cab bushing height
Hey guys, I need someone to measure a fairly fresh cab bushing spacing from the solid frame mount to the cab floor. Front and back. One side is fine. Reason is, I set my cab on the frame , just to get it out of the way, and it is rocking on my xfer case at the center brace behind the high hump hole. I may not have a problem, and again I may. Thanks.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
![]() Join Date: Dec 1999
Re: Measurement PLEASE. K10 cab bushing height
Sorry you have not had any response. Will get you some measurements tomorrow later in the day. I installed mounts purchased from Classic Hearteat (Wes). Note the mounts I had originally installed from LMC were to short by 3/4"- to 1". Not any interference though. Have seen on the forum that this is not uncommon. Owned a K-20 and currently a K-10 I am working on now myself. From what I understand K10, K20 and C20 rear mounts are al the same. Only the C-10 rear cab mounts are different.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Thank you. I have a set of bushings, (unopened), and since I swapped this over to a different case, I am thinking I have clearance issues. My bed is perfectly aligned so if the cab works out. Im good.
![]() Join Date: Dec 2014
Tutone,
Hope these help. Let me know if you need a different angle or measurement. Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears |
Also, I haven’t measured floor to mounts or cab brace yet. My bolts may be loose which may cause these measurements to be slightly off.
Roger
Thank you sir. My cab mounts are in the correct place so no further measurements required. I assume that after replacing your bushings with these, you are happy with cab to bed alignment. Otherwise, you would be like me searching for the right height. I will cut spacers to that height and slip them in to see if I do in fact have a problem. Seeing the 2 5/8 measurement on the back gives me hope.
Yes sir, cab sits nice and no movement when I work on it. I may tighten down a turn or two still. Glad I could help.
