![]() Join Date: Dec 2014
Re: Measurement PLEASE. K10 cab bushing height
Also, I haven’t measured floor to mounts or cab brace yet. My bolts may be loose which may cause these measurements to be slightly off.
Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears |
Thank you sir. My cab mounts are in the correct place so no further measurements required. I assume that after replacing your bushings with these, you are happy with cab to bed alignment. Otherwise, you would be like me searching for the right height. I will cut spacers to that height and slip them in to see if I do in fact have a problem. Seeing the 2 5/8 measurement on the back gives me hope.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
Yes sir, cab sits nice and no movement when I work on it. I may tighten down a turn or two still. Glad I could help.
