![]() Join Date: Aug 2019
Re: New 68 Stepper Build...IM BACK!!
I bolted my tank in then used the strap kit.
#2 | |
I'm in agreement w/these guys. 'Was the tank flange designed/intended to support the weight w/o the straps? ' would be what I want to know.
![]() Join Date: Jun 2009
There was no strap kit available for this tank. Looks like I’ll be calling tanks inc.
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
#4 | |
The tank was designed to be installed to the bottom side of the frame. There are no straps or additional support required as the flange was designed to hold the weight of the tank, fuel, and components installed. You can install it in between the frame rails or even on top but it was designed to be hung from the bottom side of the frame rail with 2 bolts on each side. She said to use 3/8 or larger to secure the tank
#5 | |
What tank p/n BTW?
#6 | |
https://www.tanksinc.com/index.cfm/p...rod/prd821.htm https://www.tanksinc.com/index.cfm/p...rod/prd822.htm https://www.summitracing.com/search/...rd=tanks%20inc
#7 | |
As for the job offer, it would depend on the offer if it was me. I've been in the Arlington store. It's a mix of knowledgeable & former O'Reillys/Autozone help. What would you be doing for them?
#8 | |
We do pressure washing and landscaping. Miller Svcs, LLC. Went full blown LLC in the beginning of 2020. We do a few other things but nothing crazy. For the most part, like 70%, Im at home anyways. Most of our stuff is done at night and my yard crew runs during reg. hours. We do ok with the contracts I have, but I decided I wasnt going to take a wage from the business and just reinvest. I get 90% disability from the military and TBH, thats really all i need. When i was laid off in 2014 and in 2016, I rearranged my budget. Have been good ever since. Only real downside to the whole thing was the contributions to my IRA.
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 Last edited by 77chris03; 02-01-2022 at 01:19 PM. |
Tags |
slick67 |
