Old 03-02-2022, 11:18 PM   #1
Denver9
Instrument cluster ground
Where does the ground cable plug into the instrument cluster on a 74 Chevy C20 pickup? A picture would be helpful. Also, if the instrument light sockets are loose when plugged into the cluster, are shims available to achieve a tighter fit of the socket?
- Denver9
Denver9 is offline   Reply With Quote
Old 03-03-2022, 01:22 AM   #2
Accelo
Accelo's Avatar
Re: Instrument cluster ground
I just slightly bend up the brass contacts on the twist socket with a small screwdriver. The ones for eye glasses work great. Clean them first if they are dirty.
I like to test the bulbs at the same time with some alligator leads connected to the tabs. Easier to do this first before bending them. I have found many bulb that do not light but only require a nudge in the socket to get working again.
Accelo is offline   Reply With Quote
Old 03-03-2022, 12:04 PM   #3
Big Kev-O
Big Kev-O's Avatar
IF you have a 7 hole cluster it would be terminal number 7 on the connector which is a Black wire on the end of the plug. It is mapped out in orange on the diagram below.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 03-03-2022, 01:46 PM   #4
pjmoreland
pjmoreland's Avatar
Welcome! If your truck is a 74, then you might have better luck posting your question in the 73-87 forum:
https://67-72chevytrucks.com/vboard/...isplay.php?f=4
pjmoreland is online now   Reply With Quote
Old 03-04-2022, 12:45 AM   #5
stepsider
stepsider's Avatar
Big Kev-O or anyone else, New a wiring diagram for a 1972 C10 3 hole dash.
stepsider is offline   Reply With Quote
Old 03-04-2022, 02:03 PM   #6
Big Kev-O
Big Kev-O's Avatar
Is this what you need?
Old 03-04-2022, 02:56 PM   #7
stepsider
stepsider's Avatar
yes, thank you
