Old 03-03-2022, 11:41 AM   #1
stepsider
stepsider's Avatar
Gas tank filler tube
I put a Gas tank in my truck bed. Need to fill the hole. Cut the filler tube from the old gas tank. With a new rubber for the hole, a hose clamp and the tube, The rubber went on first then slipping the tube in putting the clamp on from the back and tightening it. Well another DIY done
stepsider is offline   Reply With Quote
Old 03-03-2022, 12:29 PM   #2
mkmc69
mkmc69's Avatar
Re: Gas tank filler tube
Seems pretty simple and cheap to do. Good idea.
mkmc69 is offline   Reply With Quote
Old 03-03-2022, 07:30 PM   #3
FRCvette
How did you cut filler neck off tank. I wanted to do that but was afraid.
1968 c10 swb Stepside
FRCvette is offline   Reply With Quote
Old 03-03-2022, 09:15 PM   #4
72c20customcamper
72c20customcamper's Avatar
Did you block the tube hate to see anything get in there specially gas
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-03-2022, 10:08 PM   #5
Accelo
Accelo's Avatar
Seems you have found the Only good use for an old fuel tank!
Might be able to cut it off with a large pipe cutter or a muffler cutter.
Accelo is online now   Reply With Quote
Old 03-03-2022, 10:51 PM   #6
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Nothing New. I did this years ago. Good idea
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 03-04-2022, 12:06 AM   #7
stepsider
stepsider's Avatar
The tube came off my truck when I put a new tank in the bed. No gas was in the tank when I cut the tube I air out the tank about three weeks. Cut it with a saws all. Going to blank off the tube at the top from the inside welded
Old 03-04-2022, 02:08 AM   #8
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by 1970 cst short wide View Post
nothing new. I did this years ago. Good idea
x2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-08-2022, 03:40 PM   #9
dz1087
I used a sawzall and cut it right off. Mine was dry when I did this. If you're worried about fumes, drain it, and fill with water. Cut. Drain again.
dz1087 is offline   Reply With Quote
