Old 03-07-2022, 12:10 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Aftermarket door wedges
Curious if anyone has tried these: https://www.ss396.com/chevelle/KDW-68A.html
The brass wedges and spacer appear correct. Not sure about the striker plate.
Old 03-08-2022, 09:38 AM   #2
1rippen6
Re: Aftermarket door wedges
If heard the wedges and the shims are correct but the stainless steel striker is not. I haven't tried, just going by what other people have told me.
1rippen6 is offline   Reply With Quote
Old 03-08-2022, 10:35 PM   #3
Tmend
Tmend's Avatar
Yes I have personally used them. The brass wedges and shims fit perfect. The stainless plate however completely wrong size and holes don’t line up. Here are some comparisons I took. The larger one is the blazer/Jimmy one.
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 03-09-2022, 09:33 AM   #4
DGinney
Probably would still work I'm thinking? I need a set so this is good info. Thanks!
DGinney is offline   Reply With Quote
Old 03-09-2022, 10:29 AM   #5
Tmend
Tmend's Avatar
You’d have to oval out the holes to get them to screw on. Even then the there is less contact area and may result in damage. I would use the small stainless stainless plates. You check the for sale section or put up a want to buy post
Old 03-09-2022, 12:43 PM   #6
hemi43
hemi43's Avatar
Those would be very easy to make with simple tools. I had no idea there were no aftermarket available.
hemi43 is offline   Reply With Quote
Old 03-09-2022, 06:42 PM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good deal guys. Thanks for the replies.
