Exhaust
Can anyone tell me what exhaust manifolds came stock on a 1972 K-10 with a 350 ? I purchased the center dump ram horn manifolds that exit straight down but when I look for a dual exhaust kit it looks like the pipes are bent for the manifolds that exit on a 45 degree angle.
Re: Exhaust
If I recall, my '71 ram horns do in fact kick back on the driver side, but are mostly vertical on the passenger.
Those aftermarket manifolds are just straight up and down. Which is but one of many reasons I avoided these. Instead, I filed flat the flange, heli-coiled the stud holes, and then blasted and hirsch painted my originals.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
Re: Exhaust
I pulled this one off an internet search. It is a big block, but the small blocks were very similar. Pass side dumps at about a 45 degree angle and looks about like that one on the DS except for the heat riser damper, which by the way will probably be inoperable after 50 years. I prefer the ram horns myself. I will have a custom exhaust bent for mine, and that may not be an option you want to use.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
Re: Exhaust
if you want oem exhaust to bolt up.
Use oem. manifolds. |
#5 | |
![]() Join Date: Apr 2012
Re: Exhaust
![]() Join Date: Jan 2001
Re: Exhaust
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Nov 2013
Re: Exhaust
I just these off my 72 c10 with a 350 motor. Hope it helps.
Roadtrip!
![]() Join Date: Feb 2003
Re: Exhaust
This is correct.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again... 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: Exhaust
But he has a K-10...
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Exhaust
Assuming K10 is same as K20.... mine (72 K20) with a 350, both sides center dump straight down. Just as mentioned in posts above. OP, it seems the exhaust kit you're looking at is incorrect.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Active Member
![]() Join Date: Dec 2003
Re: Exhaust
I Have 1972 K10. the exhaust manifolds are center dump that extend straight down, both sides. my truck has single exhaust that terminated on the driver's side just behind the rear fender. my truck is a short bed step side.
The driver's side header pipe drops straight down and bends to the rear along the frame rails. The passenger side drops down bends to the rear then crossed over behind the transmission pan and connects to the drive's side pipe. I have the original pipe. I have not been able to locate the header pipe. I had one made up by a muffler shop but the reproduction was not exact and needs to be modified. I will try to get a picture of the pipe and post it to this site. |
![]() Join Date: Dec 2013
Re: Exhaust
On my 67 2wd , I'm using the 2 1/2" center drop manifolds and they will require a custom exhaust . Using 2 1/2" pipe it will need to be bent like these pipes to clear everything . So you may have to do the same ? 4" radius bend using 2 1/2" pipe
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 03-26-2022 at 12:04 PM. |
