Old 03-24-2022, 08:57 PM   #1
custom10nut
custom10nut's Avatar
Carpet Difference?
What are the differences in the types of ACC Replacement Carpets?
I find 80% rayon/20% nylon
With or without “MASS Backing”
What are the advantages of the MASS.backing?
I see it’s thicker that the non-Mass carpet and says it’s better for sound deadening and heat shielding, but will the extra thickness give any fitment issues with my Gas Pedal 70 with the two floor mounted “Ball Studs”.
The carpet that’s in my truck now is not factory, and has a thick padding under it, that makes keeping the floor mount accelerator pedal in place a PITA.
I’m wide open for comments guidance and opinions
custom10nut is offline   Reply With Quote
Old 03-24-2022, 11:18 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Carpet Difference?
I used the ACC 80/20 carpet with mass backing and would buy it again. I did cut off part of the edge binding on both sides to allow for a better fit under the sill plates. This is also what the factory did, at least on my truck. The first two pictures below are the original carpet. I removed the area between the 2 arrows so it matched the original.
I was also concerned about the studs. Frankly, I don't recall if I made any changes there. If I did it must have been something minor. I do not have any problems using the original accelerator.
The third picture shows the installed carpet with the ACC carpet mats in place.
Jim
FirstOwner69 is offline   Reply With Quote
Old 03-24-2022, 11:45 PM   #3
Grumpy old man
Grumpy old man's Avatar
Always buy with the mass backing , when it arrives take it out of the box and spread it out to allow it to relax from being stuffed in the box and get rid of any box wrinkles , on the driveway on a sunny day or somewhere warm and dry works .
Old 03-25-2022, 01:52 AM   #4
custom10nut
Thanks to both of you for the guidance and tips.
I’m about to tear into my truck to finally get it finished.
The new carpet will complete the interior.
Old 03-25-2022, 01:58 AM   #5
custom10nut
What way do I adhere the new carpet to the cab floor? Or do I?
Does the carpet just sit on the floor and get held in place by the seats and sill plates?
Old 03-25-2022, 09:01 AM   #6
cj847
cj847's Avatar
The carpet just sits there. No adhesives needed.
Another tip. Have a round bar, some old sockets, and a propane torch. Anywhere you need a hole pic the appropriate size socket or rod, heat it up and melt a hole in the carpet. This will singe the fine fuzz together and make for a really professional look and make assembly much easier (the fuzz at the edge of a hole is notorious for finding its way into the threads of your fastener).
cj847 is offline   Reply With Quote
Old 03-25-2022, 07:39 PM   #7
custom10nut
Thanks for the tip
Old 12-21-2023, 12:05 PM   #8
z10kl
z10kl's Avatar
I see nobody answered your question about mounting the gas pedal with the mass backed carpet. I’m having that issue now. I may have to extend the ball studs. Anyone solved this problem?
70 CST
Bunch of old Camaros
z10kl is offline   Reply With Quote
Old 12-21-2023, 12:28 PM   #9
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
I scraped away some of the backing around the pin holes in a rectangle slightly larger than the pedals profile to let the carpet sink a little to let the pedal squash down onto the pins. It was still a pain, took a piece of wood and to hold onto the pedal that I could hit a hammer. Couple solid hits and it finally seated in.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 12-21-2023, 01:31 PM   #10
68 C10 Driver
I purchased the carpet with the MASS backing on it and had no issues with the gas pedal staying in place on the ball studs. I also used no adhesive when installing the carpet. The carpet lays nicely and when the sill plates are finally installed along with the bench seat it will be more than secured.
68 C10 Driver is offline   Reply With Quote
Old 12-21-2023, 01:35 PM   #11
HO455
HO455's Avatar
Nice color.
RIP Bob Parks.
Old 12-21-2023, 01:37 PM   #12
68 C10 Driver
Thanks, it is perfect with the interior cab color. This was just after I put it in to see how it looked, it has relaxed a lot and doesn't look so wrinkled now.
