Re: Electric Choke Wire?
No need to tie into pressure switch. If key left on, ignition coil will also discharge battery. So, point is moot. No?
Easy method that looks original is to route from key-on terminal at fuse block; thru light blue, 16 awg, gxl wire with inline 3A fuse; out thru existing firewall grommet and to choke coil. Route wire adjacent to valve cover and install asphalt cloth jacket to make look factory.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
| Bookmarks |
