Re: Supporting engine when removing trans
What? Why would that happen? You yank the prop, unbolt the transmission, slide it back, and drop it down. That's it.
![]() Join Date: Mar 2003
The exhaust system usually will hold up the engine enough. If I have to move the car/truck substantially I will either thread in a couple of long 3/8'' bolts into the lower bellhousing bolt holes and set a 2x2 across the frame rails or just use a heavy duty ratchet strap rail to rail. The early 4x4s with the engine stuffed into the firewall need the dist cap loosed so it doesn't get broken.
If you are not moving the truck then what you propose will work just fine and be relatively solid |
#3 | |
![]() Join Date: Jul 2000
Thanks to the guys with helpful comments and suggestions.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 06-23-2022 at 06:09 PM. |
![]() Join Date: Feb 2016
Worst-case scenario is the motor mounts are broken and the exhaust pipes are paper thin. Then the engine falls backwards and breaks the shroud, the fan hits the radiator, the distributor cap gets broken and oil pan gets crushed exactly 37 minutes after you pull the transmission.
I'm not pessimistic, I've just spent a lot of years working on junk. ![]() It's always better to be safe than sorry in my world.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#6 | |
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
