#176 |
Re: The Vandal. 1957 "Big glass" 3100 restomod.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
#177 |
truck looks amazing
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90 http://67-72chevytrucks.com/vboard/s...d.php?t=746958 |
#178 |
![]() Join Date: Mar 2011
Beautiful truck...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#179 |
![]() ![]() Join Date: Oct 2014
WOW!!! NICE!! Looks like that's the north end of Eagle Rd/Willow Creek.
#180 | |
Thanks for all the comments! Still working out lots of little issues, but at least it's usable. It has a cooling issue, that doesn't make sense. I have a 2 speed fan wired with relays per the instructions on lt1swap.com. It works great, until it doesn't... The low fan logic has blown out 2 relays and one fuse. I have tested the logic multiple times by grounding the leads to fan1 and fan2, like the computer does. When cruising with good airflow, the water temp (reading from the ECM) cycles between 200-210. Somewhere in that range, the computer turns on the low fan. I have no idea what temperature the computer turns on the high fan, or if it is even programmed to do so. Anyway, once the relay "blows", it starts cycling like a turn signal, and the water temp runs up to 225+ and I shut 'er down. Long story, after getting home and sitting all evening, there's a big puddle of coolant on the garage floor. I haven't investigated yet. It looks unrelated to the fan issue. Possibly a heater hose or the coolant overflow can.
#181 |
The coolant leak turned out to be a heater hose clamp that never got tightened.
![]() Swapped in another relay, different brand this time. Going for another test run.
#182 |
![]() Join Date: Mar 2007
Very, very nice. Way to go. Love it.
Marc
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#183 |
Thanks!
I think the cooling problem is computer related. Somewhere in the 210 temp range it cant make up it's mind to run fan LO or fan HI. The cycling causes the relays to overheat. When I pull out the relay, it is SO HOT that I can't touch the prongs. Looks like I'm going to have to find a local tuner to take a look at it. Problem 2 could be a stuck thermostat. Since this engine had been sitting for 13 years, I put in a new 187 thermostat before getting it running. The new thermostat housing leaked on the first fill, so I glued it on with "The Right Stuff". I wonder if some got into the thermostat and glued it shut. When the engine temp is showing 210, the infrared thermometer shows the top of the radiator to be 200 degrees, and the bottom is only 130. Anyway, it's going to be a while before I can troubleshoot it.
#185 |
![]() Join Date: May 2007
this is one of the best trucks on the website! beautiful job!
#186 |
![]() Join Date: Oct 2009
Looks great!!!
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#187 |
BG
This TK is sweet, grand job. keep on keepin on Strong Work nutz
Been there, wrecked that
#188 |
![]() Join Date: Dec 2020
that sir,is one gorgeous truck.the metal work is top quality,a real beauty.
#189 |
![]() Join Date: Apr 2016
She has turned out beautiful. Very cool ride. Enjoy.
#190 |
Hey, I saw your truck at the Eagle Fun Days. It looks even nicer in person!
#191 | |
Thanks to everyone for the positive comments, it keeps me going!
Thanks! I couldn't believe how much attention the truck got! When I was at the truck, lots of people stopped to talk about it. I was bummed that the parking dude made me park in the dirty lot back 40. Seriously, he told me to get a rag and quit crying!! Either way, I still had a good time, enjoyed "talking shop" with others. Now I'm motivated to work on more finishing touches. And, when I got home, my new bumpers were waiting in the driveway!
#192 |
#193 |
Truck looks amazing. Drive and enjoy the fruits of your labor!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jasons 56 build |
#194 |
Looks really sharp. well done
#195 |
Great pics. Looks good out in the wild.
Marc
#196 |
gorgeous man!
#197 |
Great truck...Jim
#198 |
Looks great. Be thankful you're done. Given todays circumstances and inflation many would not start a project like yours. Again Beautiful truck and congrats!!!
#199 |
![]() Join Date: Aug 2010
The LS engines run at 210* normally. Your radiator is doing its job cooling .
Now as for the fan cycling you can adjust the on and off temperature for both fans with a tuner via the under dash diagnostic port . If the relays are getting to hot it could mean the fans are pulling too much amps.
Glen & Jane's Rides 57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#200 |
Check out the pirate 4x4 site for bella vista's write up on the ls cooling system and how it works. You cant think like the old school systems with an ls engine.
I would do an amp draw test on the motors if the relays are getting hot. |
| Bookmarks |
