Old 09-01-2022, 07:01 PM   #1
ron350
ron350's Avatar
Valve cover oil filler funnel.
About a year ago a mechanic showed me a Hiper Tough funnel #05071 bar code 817739011036. This funnel fits the valve cover oil full hole on my 75 -350 and does not move until you are ready to remove it. This funnel allows me to add oil with out having to removing the air cleaner.
I liked the funnel so much I went to Walmart to purchace another one but now they are no longer stocked.
Does any one know where I might find another one of these funnels?
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is online now   Reply With Quote
Old 09-01-2022, 07:24 PM   #2
74C10Y
74C10Y's Avatar
Re: Valve cover oil filler funnel.
Did you try Walmart online? Shows Lowe's carries it under this code,
https://www.lowes.com/pd/Hopkins-Sup...el/1002352150?
74C10Y is offline   Reply With Quote
Old 09-01-2022, 09:16 PM   #3
ron350
ron350's Avatar
74C10Y thank you very much for finding the same funnel at Lowes.
Now I have 4 spare funnels that are labeled FloTool #05062.
Old 09-02-2022, 07:23 AM   #4
cadillac_al
I have been using the blue rectangular ones from the parts stores. Those lock into the fill hole too and I can let the oil bottle lay in the funnel for 5 minutes and drain every drop out of it.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 09-02-2022, 11:16 AM   #5
72c20customcamper
72c20customcamper's Avatar
I bought a couple of these at tractor supply there about 8 bucks
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-02-2022, 11:57 AM   #6
kwmech
I've been buying the transmission funnels and cutting them off where I need to have hem fit snug in the hole. Just pour a quart at a time. Goes pretty quick. The extra drippings go into a gallon jug for my chainsaw bar
Old 09-07-2022, 11:20 AM   #7
65chevysub
65chevysub's Avatar
I'm looking for the factory tube that goes in the valve cover that the cap goes on. If I can't find one, I'll switch the valve covers around so my fill hole is on the right bank in front instead of under the brake booster.
65chevysub is offline   Reply With Quote
