Rear differential bearings
Ok I was pestering about lowering my 66 c10 and endlessly debating if I should buy a chassis from a 71 for a 5 lug conversion. Long story short I bought the chassis and just got done tearing the rear apart. Kind of disappointed in its condition but I suppose it could be worse. The only major issue is the passenger side backing plate is wasted and the outer bearing fell apart. I've replaced axle seals before but never any bearings. I did get the race in the tube out with a slide hammer but I think the ring gear and carrier should at least come out for a thorough cleaning. I know those main caps need a very specific torque but beyond that I'm looking for any advice so I dont end up destroying the whole thing. Thanks
Re: Rear differential bearings
Just keep each shim on its correct side, and you should be good.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Did you use the 71 rear or just the 5 lug axles? I am starting to look for a set of 6 lug, 30 spline, 30.5 inch axles. I want to keep my 63 housing, but I can't get a posi for 17 lug axles.
I'm using the whole rear end, maybe. I say maybe because things arent going as planned lol as I'll elaborate in another message in this thread
Well what I was foolishly hoping was just going to be a fluid change and axle seals has ballooned lol. After the teardown I knew the seals were bad so consequently the outer bearings needed changing as well. Being that far into it I took the carrier out because I may as well change those bearings as well. In doing so I noticed the pinion bearings were crunchy so I removed it. Having the carrier out I was better able to inspect things and noticed the teeth not submerged in gear oil are slightly pitted. It's going to be an occasional driver so I dont know how the pitted ring gear will affect longevity and what do I need to know installing new pinion bearings? Like I said earlier, I've never been this far into a total diff rebuild
I'm wondering when I should cut my losses and start looking for another rear end which may or may not be in better shape.
You're really going to want a press and a bearing splitter to change the bearings, or you can take the parts to a shop and have them pop the old ones and install the new ones.
Ideally you should re-check everything (bearing pre-load, tooth patterns) as you put it all together, but you can often get away with just putting it back together the same, and not over-torquing the pinion nut like a monster. There is a sleeve in-between the front and rear pinion bearings (looks like a deformed section of tube) that sets the pinion pre-load - DON'T distort it more by over-tightening. If you have no money, you can do this. But sometimes "pay the man" is a good thing with ring & pinions. If you don't have a limited slip in there, considering buying one now - this is a good time to put one in. Post a pic of the pitting. You can actually get away with quite a bit of nasty.
#8 | |
I am heading to Carlisle tomorrow and will be shopping for axles. If you do get this one together and you use the entire rear, let me know if you may want to move your original 66 rear. I am not too far from Hersey and may be interested. Good luck with the one you have.
Rob |
In my opinion, those gears are too far pitted; I'd expect them to be noisy. I hope others here will chime in too.
Do you know if it made noise before you took it apart?
#11 | |
Those gear teeth are far beyond useable, but for an occasional driver just doing a weekend cruise once in a while and driving it like granny, it'll probably work.
Yea many moons ago when I was a dumb cheapo teen mostly because I didn't have two dimes to rub together I would have absolutely reused these gears and every once in a while I hear him trying to convince me to go the cheap route so I knew these gears were toast. So in the near future after i decide to buy new everything I'll be looking for tips on setting preload and centering up the carrier. Thanks everyone
![]() ![]() ![]() Join Date: Jan 2018
Was the 6 lug ring and pinion bad as well? If you aren't planning on changing the gear ratio as well, just use the carrier and R&P from the 66 axle in the 71 housing
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#15 |
The 66 is geared at 3.73 and I was hoping to go to a higher ratio with this change to 3.40 or 3.08. The 71 is geared at 3.08 but rebuilding it has me a bit worried
#16 |
Ahh, I see. I bet you could source a good set of used 3.08s from someone switching to 3.73s. Maybe someone would want to trade your 3.73s and carrier for 3.08s
#17 |
After copious gobs of deliberation I've decided to rebuild the toasted rear. I scanned the interwebs looking for a rebuilding guide either in written form or instructional video and after wading through a lot of videos of people with good intentions but lacking the ability to instill trust in me that they were doing things correctly. Finally I found a 2 hour long video of a gentleman from a technical school demonstrating how to rebuild a gm 10 bolt differential. Yes I know I'm rebuilding a 12 bolt but the concept and processes are the same and I'm confident now that I can get this done. I'll provide the link below for anyone interested in a fine demonstration. My next step is getting parts ordered from summit and finding a decent set of backing plates.
https://youtu.be/AsiRYnWcCQg |
#18 |
![]() Join Date: Jan 2011
What did the axles look like where the bearings ride? Were they pitted or worn? You had said the rear had one bad bearing.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#19 |
#20 |
![]() Join Date: Mar 2011
I recently rebuilt the rear diff in my 66. It's not an easy job but just take your time. I bought a new Eaton tru-track, Richmond Gear ring & pinion. and the kit that has all of the shims, bearings. crush sleeve, and all parts needed to complete the job from Summit. I found a video on YouTube made by the Haggerty company that was very thorough. Good luck, it will be well worth your time now rather than having to do it all over again later.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
#21 | |
| Bookmarks |
