Old 10-10-2022, 02:36 PM   #1
OregonNed
OregonNed's Avatar
Question before I order new battery cables
Could I just verify with someone - is the solenoid lug for that side of the battery cable 1/2 inch? Just didn't want to order them and have that side wrong. Thanks in advance!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 10-10-2022, 02:47 PM   #2
RustyPile
RustyPile's Avatar
Re: Question before I order new battery cables
The cable stud on a GM solenoid is 3/8"...
RustyPile is offline   Reply With Quote
Old 10-10-2022, 03:12 PM   #3
OregonNed
OregonNed's Avatar
Fantastic! Thanks for the help!
Old 10-11-2022, 05:51 PM   #4
OregonNed
OregonNed's Avatar
Ordered them last night on batterycablesusa.com site and they shipped this morning. Looking forward to seeing them from all the good things I have heard..
Old 10-11-2022, 06:23 PM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
What did that run you?
I bought a 48'' 2 gauge Red cable with Solenoid and Top Post terminal ends for about $25 off the rack at Tractor Supply. Worked perfect on my 292 L6.
Old 10-11-2022, 06:28 PM   #6
OregonNed
OregonNed's Avatar
I bought made to order 4 GA cables - with the correct ends (top mount battery) the longest one, (54 inches) was $18
Old 10-13-2022, 10:05 AM   #7
Grumpy old man
Grumpy old man's Avatar
I ordered from batterycablesusa.com bulk 2 gauge the flux /lugs and slugs to build my own cables and a few heavy duty extra ground cables and the shrink wrap , Probably enough to build 2 sets and it was $67.00 .
Old 10-13-2022, 11:52 AM   #8
72SB
Like fan belts, battery cables can be ordered by length and cable size. I used AC Delco site to look up that 411 for the cables I bought. #2 side post type. They were not much $ on Amazon. I use a side post 78 series battery. IMHO a cleaner look vs top post
This is what I got
- $21 ACDelco Professional 2SD35X Battery Cable
+ $35 ACDelco Professional 2SD43XG
I did need to swap the post on + cable as it was too long. I assume that whatever vehicle specific application that cable is for uses an additional + cable secured with the longer stud. $1 to buy standard length battery stud
Depending on your desired routing path, just measure that length and look up the cable by # (i,e, 2SD= 2 gauge, 35X=35", G= insulation)
Nothing wrong with rolling your own if you buy parts. Need a good crimp tool, shrink tube
72SB is offline   Reply With Quote
Old 10-13-2022, 04:32 PM   #9
OregonNed
OregonNed's Avatar
Cables came today in record time - they look awesome..
Old 10-13-2022, 04:52 PM   #10
MikeB
MikeB's Avatar
I love those guys! $41 for a custom-built 2 gauge pair -- including shipping.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-13-2022, 06:22 PM   #11
'68OrangeSunshine
You can also solder them on with a propane torch and enough flux.
Old 10-14-2022, 04:32 PM   #12
basketcase
basketcase's Avatar
I ordered from them too. 2ga wire to my length specification and the ends I wanted for a great price. I was really impressed with the company.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 10-14-2022, 04:43 PM   #13
LS short box
That's looks good. Can't hardly buy good cable for that.
