Old 10-17-2022, 08:09 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Was being a GMC an option???
Odd...
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-17-2022, 08:22 PM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Was being a GMC an option???
General Motors Corporation?
Garage Man's Companion?
What's Z86, again?
~Steven
Simi Valley, CA
Old 10-17-2022, 10:27 PM   #3
68bowtie
68bowtie's Avatar
Give Me Chevy!
Old 10-17-2022, 11:17 PM   #4
Steeveedee
Steeveedee's Avatar
It would be interesting to see the rest of the vehicle...
~Steven
Simi Valley, CA
Old 10-18-2022, 02:47 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
What's Z86, again?
Government
Model
Chevrolet
Looking at the VIN on the SPID, it's a C/50 with a 174'' wheelbase.
Old 10-18-2022, 08:38 AM   #6
Get More Cash?
I don't see it as GMC since there are periods typed between each letter, I figure, to distinguish from GMC
Old 10-18-2022, 10:16 AM   #7
MJN
MJN's Avatar
What's Z86, again?
I show Z86 as Heavy Duty, 22000# GVW
Z88 is the RPO for GMC Conversion
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 10-18-2022, 11:57 AM   #8
Keith Seymore
Keith Seymore's Avatar
Yep.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-18-2022, 12:14 PM   #9
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Is that a 174" wheel base.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 10-18-2022, 05:24 PM   #10
Accelo
Accelo's Avatar
Got Mechanic Coming
Accelo is offline   Reply With Quote
Old 10-18-2022, 07:12 PM   #11
Steeveedee
Steeveedee's Avatar
Yes. It's also "incomplete vehicle certification label", so was possibly going to be a bus or something like that.
~Steven
Simi Valley, CA
Old 10-18-2022, 09:15 PM   #12
Originally Posted by Accelo View Post
Got Mechanic Coming
Greatest Machine Created
Old 10-18-2022, 11:03 PM   #13
too much stuff
Roadtrip!
Originally Posted by Keith Seymore View Post
Yep.
K
Can you expand on that?
This one had a fuel tank on back.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 10-19-2022, 08:06 AM   #14
I'd like to know more on GMC being an option, too.
This is a medium duty cab & chassis and the 174" wheelbase is just a normal WB offered. It's only 15" longer than a 157" WB C/30
Old 10-19-2022, 09:59 AM   #15
MJN
MJN's Avatar
Based on the model number it was just a cab/chassis- an upfitter would put on a dump bed or tanker on the back.
CE56803=
C = conventional cab (S for school bus chassis, T for tilt cab)
E = V8
5= C50 series
68= 108" cab to axle (this would be '18' if it was a Chevy)
03= cab except full air brakes
'17 GMC Yukon XL
VCCA member #58596
Old 10-19-2022, 12:55 PM   #16
Keith Seymore
Sure.
The model code is not "nameplate" specific; ie C10703 or K30943 doesn't tell the operator what brand vehicle it is.
RPO Z88 is the "nameplate conversion" option that specifies that everybody needs to put GMC emblems on the truck.
Similarly, there is a "Chevrolet nameplate conversion" option (I wanna say X88) and, in later years, a Cadillac RPO (aka Z75).
All these trucks were run down the same line.
K
1979-1986
1986 - 2019
Old 10-19-2022, 02:25 PM   #17
57taskforce
All about them K’s
57taskforce's Avatar
Awesome info Keith. Learn something new every day.
Tyler
Old 10-19-2022, 10:14 PM   #18
too much stuff
Roadtrip!
Thanks keith.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 10-27-2022, 08:13 AM   #19
Ok, so if I understood that right, both Chevy and GMC were options since both brands were identified as one truck line. It was more like a selection than an option. You HAD TO select one or the other. There was no going without it like with an option. Like paint color, you get choices but paint is not an option, it's a selection
Old 10-27-2022, 09:29 AM   #20
Keith Seymore
You could think of it that way, but they were called "options" (ie, RPOs) nonetheless.
In some cases if you didn't choose there was a default option. For example, if you didn't choose a color then you got the tan exterior picked for you.
Maybe powertrain is a better example. There was a base engine, a base transmission, and a base rear axle. If you didn't choose anything then you got the base powertrain combination, but each of those was still defined by an RPO.
Additionally - everything had to balance out when the Engineering Specifications group ran their "cross balance" report to make sure all the combinations were covered.
So for every option there had to be a contrasting "negative option" to balance it out, enabling Specs to run their computer generated report and ensure there was a part number created to cover all the proliferation of option combinations.
K
1979-1986
1986 - 2019
Old 10-27-2022, 09:36 AM   #21
Keith Seymore
It's a required selection that's formally called an "option".
I guess.
(lol)
1979-1986
1986 - 2019
Old 10-27-2022, 10:21 AM   #22
Steeveedee
Steeveedee's Avatar
I recall seeing that one could buy a vehicle in primer. That was in '71. Not sure why someone would do that, since it would be really difficult to get everything painted after the vehicle was assembled.
~Steven
Simi Valley, CA
Old 10-27-2022, 10:42 AM   #23
I guess.
(lol)
Thanks for letting me pick your brain on that. I may put them as selections in my mind to make it work for me, but I like learning how it actually was for GM and why. Keep it simple and clear. Not trying to write a novel
Mom says I've always been curious
Old 10-27-2022, 11:10 AM   #24
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Really good info Keith, learned something new!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-27-2022, 12:07 PM   #25
Keith Seymore
So you could have it painted in a color not normally available. If you owned your own company and wanted to paint it Petty blue, or whatever.
Back in the day - the mass production body work on a Corvette was so bad that you could not order a black car from the factory.
You could, then, get a primered car and have the prep work done and painted black after the fact.
K
1979-1986
1986 - 2019
