Old 11-28-2022, 04:00 PM   #26
72SB
Re: Pinion angle
drive shaft run out???
4:10's...that DS better be balanced dead nits and with a high RPM balancer....which few shops have
Tire balance good?
and rim bent or have run out?
72SB is offline   Reply With Quote
Old 11-28-2022, 05:05 PM   #27
kwmech
Re: Pinion angle
Originally Posted by tdangle View Post
So are you guys saying that changing from a TH350 to a longer 7004R trans and having the front section of a 2 piece driveshaft will change the angles to the point that a vibration will occur.
Nope, that's why I asked how he had the driveshaft shortened. The clocking could be off or the front section-- if shortened by itself-- may not be in balance with the rear now
Old 11-28-2022, 05:47 PM   #28
pontiacvince
pontiacvince's Avatar
Re: Pinion angle
Originally Posted by kwmech View Post
When you had the front section shortened, did you take both pieces in to the shop or just the front piece? And did you pull the whole assembly out as a whole or pull the 2 pieces out separately?
I took the whole thing to a driveline shop. They shortened the front section and installed all new u-joints and carrier bearing. I can only assume they rebalanced it.
pontiacvince is offline   Reply With Quote
Old 11-28-2022, 06:04 PM   #29
tdangle
tdangle's Avatar
Re: Pinion angle
Actually it's been balanced twice (the entire assembly including carrier support). 1st time was when I had a 2004R. It didn't need a change in length but I had it completely rebuilt, new carrier bearing, U joints and balanced. 2nd time shortened and balanced (the entire assembly again) The shop has a high speed balancer setup and said it was good.
I ran it supported on jack stands without wheels, tires and brake drums. The vibration is still there. BTW: at 45 driveshaft speed is about 2K max. At 70 nice and smooth.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 11-28-2022, 06:53 PM   #30
kwmech
Re: Pinion angle
Yes everything should have been balanced as an assy----I assume you shoved it back in without taking it apart so everything still lines up?
I'd be looking at tires and rims--possible alignment--shocks, bushings not seated etc. Can you get us a picture of the rear with the d-line showing
Old 11-28-2022, 08:19 PM   #31
kaycee
kaycee's Avatar
Re: Pinion angle
I used an app off play store seems to be pretty accurate and yes take the case off phone. I double and triple checked mine even bought a digital one to check it. I am a 1 piece shaft and installed a 700r4 that sits way low on stock crossmember 7*down on tail end and rear pinion was 2* up got the rear trans at 3*down should be good to go now.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 11-28-2022, 08:21 PM   #32
72SB
Re: Pinion angle
OP
Are you sure this is a DL induced vibration??
Have you ruled out torque converter shutter? (most common at 45mph...)
Old 11-28-2022, 11:49 PM   #33
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Pinion angle
Originally Posted by Lancialonnie View Post
This post has definitely gotten complicated! I'm working through this with my 2-piece driveshaft now. I used 4 inch lowering springs and had the front driveshaft shortened when the 700r4 was installed. After a while I realized that there was no slip in the rear section and the driveshaft had destroyed the center bearing. I just had the CPP cross member and tubular trailing arms installed along with the poly center bearing and their rear slip driveshaft. Everything looks like it will work and now I just need to have the center yoke replaced, since there is metal missing where the c clips go, and get the unit balanced. I'm hoping this will do the trick and I won't have to do any angle measuring!
You should be good to go! Theres an app on these smarter than me phones that make your phone an angle finder..."Cheers!"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-29-2022, 03:40 PM   #34
pontiacvince
Re: Pinion angle
Originally Posted by 72SB View Post
OP
No, not positive if it's the driveshaft. The torque converter is a brand new Hughes unit.
Old 11-29-2022, 03:44 PM   #35
72SB
Re: Pinion angle
Hughes is a very good TC. what I run in other cars.
Trans fluid is a typical "shutter" problem...so assume you are running the right type. This assumes trans/TC shutter is even the issue. Just thought I would add hat to the ? list if the vibration was possibly not a DL angle issue or DS balance issue
Old 11-30-2022, 10:56 AM   #36
SCOTI
SCOTI's Avatar
Re: Pinion angle
Before changing a bunch of stuff, try re-using the previous rubber trans mount. There's been more than one complaint about vibrations after switching to Poly driveline mounts.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-02-2022, 05:08 PM   #37
tdangle
tdangle's Avatar
Re: Pinion angle
to the OP, did you ever get this resolved?
Terry
Old 12-02-2022, 09:49 PM   #38
pontiacvince
Re: Pinion angle
Not yet. I want to check the pinion angle before I do much of anything.
Old 12-03-2022, 02:14 AM   #39
tdangle
tdangle's Avatar
Re: Pinion angle
Originally Posted by Ironangel View Post
Actually, shortening the front shaft doesn't change the DS angle because the carrier bearing is in the same location. The fact that you went from rubber to polyurethane mounts may contribute to your feeling something now that you didn't with the rubber mounts. Also, did you have both shafts with the carrier bearing balanced when the shaft was shortened? I dont think any of the changes you've made would affect the
pinion angle enough to cause a vibration. On page 4-24 of the service manual it describes rotating the rear shaft 4 splines to the left side of the vehicle. Model CE31403 rotates only two splines to the left. That phases the rear shaft to the front shaft regardless of the pinion yoke position. You should have both front and rear shafts with the (preferably new) carrier bearing balanced assembled together with new u-joints at a DS shop.
What service manual are you referring to? I have the 1970 service book and don't see what you are referring to.
Terry
Old 12-05-2022, 08:11 PM   #40
kaycee
kaycee's Avatar
Re: Pinion angle
If it helps any I used 1 of them ol school mechanical dials compared to my smart phone which I compared to a store bought digital which I compared to the tremec phone app and they all read different Couldnt hardly pinpoint the mechanical dial but the phone app seemed to be pretty close to it and the tremc toolbox app for the phone was way different reading. This was me squished under the car trying to get good readings . Good luck
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 12-11-2022, 12:15 AM   #41
72MARIO
72MARIO's Avatar
Re: Pinion angle
I spent a great deal of time perfecting my driveline angles. Ended up being the polyurethane transmission and engine mounts. Back to rubber now and the vibration us gone
Poly has its place..in a race car.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-11-2022, 02:42 PM   #42
SCOTI
SCOTI's Avatar
Re: Pinion angle
I mentioned this above. Many overlook this as a possibility yet it's common. Easy enough to verify as well w/o requiring other changes & should be a 1st step IMO.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-11-2022, 06:07 PM   #43
pontiacvince
Re: Pinion angle
My engine mounts are rubber. The trans mount is poly. Maybe that's it....
Old 12-11-2022, 07:01 PM   #44
SCOTI
SCOTI's Avatar
Re: Pinion angle
Anything is possible & it's easy enough to verify.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-14-2022, 02:49 AM   #45
Ironangel
Ironangel's Avatar
Re: Pinion angle
So are you guys saying that changing from a TH350 to a longer 7004R trans and having the front section of a 2 piece driveshaft will change the angles to the point that a vibration will occur. I have a C20 totally stock suspension with rear leaf and 4.10 gears. Very noticeable vibration at ~45 to 50 MPH. Both shafts were rebalanced when shortened. Shimming Carrier bearing, 2 and 4 degree axle shims, many hours later and nothing really changes. Is not wheels, tires as these have been changed.
"NO!" Shortening the front shaft wont change the rear shaft angle. Having the two shafts phased together correctly can affect the balance, or a shop unaware of the phasing procedure for these older trucks may affect the balance. A two piece drive shaft needs to be phased correctly and the carrier bearing installed on the front shaft before balancing...I wonder about alot of these shops and the man doing the balancing, sometimes their age defies experience and knowledge...
"Two Seventy Two's"
02 3/4 ton Express
Old 12-14-2022, 02:54 AM   #46
Ironangel
Ironangel's Avatar
Re: Pinion angle
I have the 72 manual. Page 4-24, the 70 manual should have the same spline phasing procedure maybe not on the same page?
"Two Seventy Two's"
02 3/4 ton Express
