Old 11-23-2022, 11:32 PM   #1
pontiacvince
pontiacvince's Avatar
Pinion angle
When building my '71 Suburban, I changed all body mounts, engine mounts, trans mount, trailing arm and track arm bushings with polyurethane. I added a 700r4 and shortened my two-piece driveshaft by 3". I also changed only the front springs with 2" lowering springs. I am getting a slight vibration at certain speeds and I am thinking it could be the pinion angle is off after changing these things. Any thoughts? Could these mods have affected the pinon and trans angles?
pontiacvince is offline   Reply With Quote
