Old 12-20-2022, 05:27 PM   #1
pound41
window regulator replacement rollers
Anyone know where to find replacement window regulator rollers for my 1975 K10
thanks
pound41 is offline   Reply With Quote
Old 12-21-2022, 08:23 AM   #2
chrismoore701
chrismoore701's Avatar
Re: window regulator replacement rollers
I pulled mine off another window regulator
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 12-21-2022, 08:26 AM   #3
cadillac_al
I have used some universal ones from the parts store help section.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-21-2022, 11:10 AM   #4
rodstored-72
chevy truck fan
rodstored-72's Avatar
I recently "revitalized my mechanisms... i need to replace mine as well. how would you go about replacing them once you have suitable replacements?
rodstored-72 is offline   Reply With Quote
Old 12-26-2022, 04:06 PM   #5
pound41
Got new rollers from AMD
ground the rivet head off
took the roller to be removed stuck it over a large socket.
used a punch and removed.
Put the new roller in place. Use a sharp chisel and cut and X on the peg
Put the mechanism roller in one side of the vice. took a pointy fender bolt in the other side. Put the bolt point in one part of the X off centered Tightened the vice. Move it to the other side of the X.
This flared both sides then I banged it flat .
took about 10 minutes to do one after I figured it out
Old 12-26-2022, 07:40 PM   #6
72c20customcamper
72c20customcamper's Avatar
Haven’t done my square but just did my 68 so I’m not sure if they are the same . Ground the peen’d part of the rivet removed the roller . Used a socket to back up the new rivet and roller , used a punch and peening hammer to flatten the peen .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 12-27-2022, 10:55 AM   #7
pound41
Nice work. The square body one's don't have a dimple on the back. They are flat so you have to cut them so you can roll them over
Old 12-27-2022, 11:32 AM   #8
72c20customcamper
So they are cross peened.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 12-28-2022, 01:16 PM   #9
rodstored-72
chevy truck fan
hhmmmm... interesting, pretty cool. nice job to both of you!! and thanks for the write up!!
