Old 01-01-2023, 12:38 PM   #1
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Buddy Bucket Seat Frame Bolt Locations
I'm putting '68 buddy buckets in my '72 (originally bench seat). What is the consensus on the red circled center mount? Should I try to drill a hole in the cab floor and install a bolt there?
Or are the two bolts on each outer edge of the seat frame adequate?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 01-01-2023, 01:35 PM   #2
kwmech
Re: Buddy Bucket Seat Frame Bolt Locations
I did with mine, along with a left over gas tank metal plate underneath as a washer
Old 01-01-2023, 01:37 PM   #3
Getter-Done
Getter-Done's Avatar
You will probably find this thread Interesting.
Link: https://67-72chevytrucks.com/vboard/...+braces&page=2
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 01-01-2023, 03:29 PM   #4
badpeanut
badpeanut's Avatar
I'm not sure if that '69-'72 bucket cab floor brace will be in the correct location for my '68 buddy buckets since the seat mounting is so different?
I do have an original '72 bucket cab floor brace I salvaged from a Blazer tub I scrapped years ago. I'll have to do some measuring.
'70 GMC LWB trailer
Old 01-01-2023, 11:15 PM   #5
Classic Bowties
Always on the hunt...
You would be correct on that, the lower center OE buddy bucket frame bracket circled in red will not line up with a 69-72 style bucket seat cab floor support brace, they are in different areas of the floor pan. Here are a few of our saved folder pics showing a 67-68 style buddy bucket seat frame and a couple of OE RPO A50 69-72 pickup bucket seat floor pans with the cross brace in place. Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 01-02-2023, 09:39 AM   #6
chewychevy67
I have had 2 1967 cst trucks 1 gmc and 1 chevy with factory buddies and both did not have that hole drilled . I did drill it in my restoration and I removed a piece from another floor so it looked stock and used it as a washer but I guess the factory did not think it was needed.
chewychevy67 is offline   Reply With Quote
