Engine upgrade
I am looking to get some solid push rods and a true roller timing chain for my 350 in my 79 stepside. Can't seem to find the push rods in summit and there are a ton of timing chains to choose from. any recommendations?
Thanks Chris
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Just here to tinker
Re: Engine upgrade
If it’s the original engine, you should be able to go to rock auto and pull up the parts you need.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
Re: Engine upgrade
Just curiously why pushrods? Lifter issues?
On a stock engine any premium double roller (like Cloyes C3023XSP) should be more than fine. To do a timing chain cover lower seal right the oil pan has to come down so may as well drop the pan and do an oil pump while it's off. (Melling standard volume is fine for stock) You may have a groove on your harmonic balancer so address that while it is off. And may as well put a new water pump on it while it's off too.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
![]() Join Date: Jul 2021
Re: Engine upgrade
Do you mean a one piece push rod. I am not sure if I ever seen a solid one in a Chevrolet. I am thinking you need the drilled push rods so oil can get from the lifter to the rockers.
Re: Engine upgrade
#6 | |
Re: Engine upgrade
| Bookmarks |
