Old 01-29-2023, 01:41 PM   #1
leftylou
Bench seat end spring replacements
I am trying to repair a seat spring that has the end support springs broken on both ends.Does anyone know if the LMC part # 30-3124 works on a on a 69-72 full foam seat? Their website says it is for 67-68. If the part will not work is there another source for the correct part?
leftylou is offline   Reply With Quote
Old 01-29-2023, 01:48 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Bench seat end spring replacements
Post a picture of what you have , I have some extra springs from different model seats Always post pictures with any questions you may have .
Old 01-29-2023, 02:11 PM   #3
leftylou
Old 01-29-2023, 02:19 PM   #4
leftylou
Originally Posted by leftylou View Post
Here are some photos showing where the springs should be.
Old 01-29-2023, 02:44 PM   #5
Grumpy old man
I'll post some pictures shortly .
Old 01-29-2023, 04:36 PM   #6
Grumpy old man
This is the type spring you need for a full foam seat . I don't know of anyone reproducing them , Place a want to buy in the parts section or try your local interior shop and see if they have a generic replacment .
Old 01-29-2023, 04:49 PM   #7
MusicMan70
MusicMan70's Avatar
Those used to be sold by USA 1 Industries 20308-part number.
You would get 4 springs back in 2018.
I only found this listing from eBay for 2 springs for about $50.
https://www.ebay.com/itm/23440082234...Bk9SR_Ko0e-_YQ
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 01-29-2023, 05:47 PM   #8
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I went up to a hobby store and bought piano wire. I should have gone to an upholstery shop. Didn't cost much, but what a female dog to bend into shape!
~Steven
Simi Valley, CA
Old 01-29-2023, 05:56 PM   #9
72c20customcamper
72c20customcamper's Avatar
Cut up an old box spring mattress to make one . Wasn’t easy to cut out it dulled out two steel bi-metal Milwaukee blades . And it was a bear to bend even in the vise
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-29-2023, 05:58 PM   #10
leftylou
Does anyone have a photo of the correct spring attached to the frame? I have a spring type frame that I can use for parts. I have removed a few springs from it but I’m having a hard time getting the support I need on the end spring without getting in the way of the foam. I suppose I could both h the foam to get around the problem but I am trying to avoid it.
Old 01-29-2023, 08:03 PM   #11
MusicMan70
MusicMan70's Avatar
https://youtu.be/uuSpXKmmYp4
Installation starts about 4:29
MusicMan70
1961 GMC Suburban
Old 01-29-2023, 08:16 PM   #12
Getter-Done
Getter-Done's Avatar
What about these?
Link for spring kit: https://www.amazon.com/House2Home-Up...5037334&sr=8-7
Link for (Just ) clips: https://www.amazon.com/House2Home-Up...5037334&sr=8-6
The early bird gets the worm,
85 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 01-29-2023, 08:31 PM   #13
TKCR
TKCR's Avatar
USA1 Industries has the springs that I use. I also double up on the end springs. I think that is why these are always broken, GM only had 1 per side. It just isn’t enough.
Old 01-29-2023, 08:35 PM   #14
TKCR
TKCR's Avatar
I also have the original sized springs if you want to use those instead of the repop end springs. After looking at your seat frame, I see you can only use one per side.
You’re welcome to them.
Old 01-29-2023, 10:26 PM   #15
MusicMan70
MusicMan70's Avatar
TKCR I just checked their website and could not find them.
Do you have an updated part number?
MusicMan70
1961 GMC Suburban
Old 01-29-2023, 11:27 PM   #16
TKCR
TKCR's Avatar
You’re right, they are not on USA1 website anymore. But that is where I always got mine.
LMC has them also
Old 01-29-2023, 11:34 PM   #17
MusicMan70
MusicMan70's Avatar
Copy that, Thank you
https://www.lmctruck.com/1973-87-che...eat-components
MusicMan70
1961 GMC Suburban
Old 01-29-2023, 11:52 PM   #18
TKCR
TKCR's Avatar
Yep, that’s the spring
Old 02-05-2023, 01:47 PM   #19
leftylou
Pm sent
Old 02-08-2023, 08:07 PM   #20
leftylou
I appreciate all of the help on this. Does anyone know if the LMC springs that are linked will fit a 69-72 seat frame? It says 73-87 but it looks like it could work.
I took some springs out of the original seat in my truck, which is not the full foam seat, and bent them so I think they will work. The problem is they are a smaller gauge wire than the broken spring which was already apparently not strong enough since they are so commonly broken. I may have to see if I can figure out a way to use 2 springs as TXCR suggested.
Old 02-08-2023, 09:53 PM   #21
TKCR
TKCR's Avatar
I don’t see why the LMC end springs wouldn’t work. The seat frame you have is pretty much identical to the 73-80 seat frames. It doesn’t say 73-87, it’s 73-80. The 81-87 seat frame was totally redesigned. So those ends springs definitely don’t work on the 81-87 seats.
Old 02-09-2023, 01:53 PM   #22
70StepsideC10
Try Bill's Truck Shop in Ontario, Canada. I linked the catalog for 67-72 parts below, I think the springs shown on page 47 (with price on page 48) are what you are looking for. When I rebuilt my bench seat I bought a length of spring, similar to what Getter Done posted above, from an upholstery shop and bent it into the correct shape. This was before I found out that Bill's sold these springs.
https://billstruckshop.com/wp-conten...2-2023-Jan.pdf
70StepsideC10 is offline   Reply With Quote
Old 04-07-2024, 11:49 AM   #23
r.e.c.enthusiasts
So. I purchased those side springs as well. But I need the long spring that that attached to.
r.e.c.enthusiasts is offline   Reply With Quote
Old 04-08-2024, 12:06 AM   #24
TKCR
TKCR's Avatar
You’re missing that entire end spring. You’ll have to find a donor seat for that.
Old 10-23-2024, 07:49 AM   #25
gmc 2500 4x4
Just saw them on E-bay
gmc 2500 4x4 is offline   Reply With Quote
