Old 03-12-2023, 11:24 AM   #26
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Best Engine Oil for 307?
That oil pressure business. The reason I used Castrol back in those days was because I had a neighbor with a Toyota pickup with a camper on it. He'd drive from California to Wisconsin to visit family and the only oil that the engine still had decent oil pressure when he got there was Castrol.
~Steven
Simi Valley, CA
Old 03-12-2023, 01:17 PM   #27
KQQL IT
At the body shop.
KQQL IT's Avatar
Best? That's a debate. But I use diesel truck oil in my junk. Mainly shell rotella 15w40
it's supposed to carry soot in the oil with their EGR systems and with my short trip traveling. It can't hurt.
And enough detergent to keep it really clean inside.
Old 03-12-2023, 01:27 PM   #28
You know, when I had diesel trucks that's what I did. I ran Rotella T 10w40 in everything. Can't hurt running turbo diesel rated oil in an old carbureted gas engine. That way I'd always have the right oil for my money maker. It was once I had oil consumption issues in the truck that took the place of my diesel that I changed it up.
Old 03-12-2023, 02:14 PM   #29
jimijam00
Clean and the correct weight.
jimijam00 is offline   Reply With Quote
Old 03-12-2023, 05:52 PM   #30
BanjoDude
Well how about that?? The local WalMart has Castrol GTX Classic 20w50 on clearance for $3/quart, so I bought a bunch of that.
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again.
"For just a little more, you can do it yourself!"
BanjoDude is offline   Reply With Quote
Old 03-12-2023, 06:20 PM   #31
howzzzit
howzzzit's Avatar
Just put a name brand 10-30 wt in it and drive.
howzzzit is offline   Reply With Quote
Old 03-12-2023, 07:26 PM   #32
Steeveedee
Steeveedee's Avatar
$3/quart is a steal!
~Steven
Simi Valley, CA
Old 03-12-2023, 09:02 PM   #33
Good answer
Not too shabby!
Old 03-12-2023, 09:43 PM   #34
chevmn
My guess is they are getting rid of all the conventional oils at walmart. I have been buying the Supertech oils at Walmart and Traveller oils from tractor supply (both arguably as good as any you can buy, and both from Warren Distribution - likely same oil as some of the name brands), and I have noticed Walmart no longer carries conventional oil in the Supertech, so I have had to buy from TSC. I also run their diesel rated oils in my diesel tractor. I have a suspicion that it will become more difficult to find conventional oils and when you find it, price will be higher I was looking tonight and a 5 qt. jug of 10w40 conventional at TSC is about $23 locally. I use full synthetic 5w30 in a Silverado truck, and it is about 21.50 (walmart supertech). I have learned you do not always get what you pay for with oils or filters. I have a driver car with over 400,000 miles which has been using Supertech conventional, but it might be soon switching to synthetic as I am not much on paying a premium for conventional oil. I suspect I will not notice any difference.
chevmn is offline   Reply With Quote
Old 03-13-2023, 07:26 PM   #35
70cst
70cst's Avatar
This
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-14-2023, 12:08 PM   #36
OregonNed
OregonNed's Avatar
Been pretty happy with PennGrade 1 in mine the last couple of changes
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 03-14-2023, 05:04 PM   #37
BanjoDude
Well so much for that! That Castrol Classic is going right back where it came from. I've never heard such a racket coming from the valve train. Goodness gracious.
Old 03-15-2023, 09:09 AM   #38
Sorry to hear that. I wouldn't want that going on for long. But maybe run it through a few short starts from cold to warm up, some revs mixed in, then a little idle time before draining. The oil is lubrication and it may be helping clear some build up out. It could be that's why it's being clackity, freed some crud up right away. I don't know what yopu are figuring on using now, but the Rotella T suggestion is a good one. Ever see diesel engine oil not long after it's been run? It gets awful black and stinky. Looks like time to change in a couple hundred miles, yet gives excellent lubrication for all day long driving as well as short stop deliveries all day long in a turbocharged engine. That's why I run it in my '72. I run the Walmart 20w50 in my '95 Suburban that was 20 years old/122k miles when I bought it. Now 28 years old/225k. I know of company fleets run on that oil. It's good oil. It's not like Walmart makes it. They just buy/sell in volume (so cheaper) and don't want law suits, so they get it from a quality producer. The proof is in the puddin' with my experience. No hi-mile oil or any other hype. Just oil that keeps my engine happy
Old 03-16-2023, 01:46 PM   #39
BanjoDude
I pulled the drain plug and filter and let it drain overnight. Filled it with Mobil1 5w40 Turbo at the recommendation of a friend who sells into automotive for a Mobil1 distributor. She purrs like a kitten again. Hopefully this helps the next guy.
Old 03-16-2023, 02:43 PM   #40
72c20customcamper
72c20customcamper's Avatar
This the GTX Classic 20-50 ? I wouldn’t run it in an engine when the temps are below 60 degrees .
I run 15-40 in the warm weather and 10-30 in cold (if I do)
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-16-2023, 06:57 PM   #41
BanjoDude
Yes sir. I took what I didn't use straight on back for a refund. The Mobil1 worked like a champ.
Old 03-16-2023, 09:52 PM   #42
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
So you had 20w50 & now you put in 5w40 why not use the 10w30 like the owners manual calls for?
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 03-17-2023, 03:54 AM   #43
BanjoDude
Very fair question. I had a long conversation with my friend who works for Mobil and learned far more than I ever thought I wanted to know about how oil technology has evolved. Pretty interesting stuff, and I wish I'd done so to begin with - would have saved me the ill-informed Castrol expirament. The net of the conversation is that the "cling" factor (my oversimplification) of some of the synthetic formulations is far greater than dino oil, which allows the wider weight spec with superior protection. This technology was obviously not available when the manual was written, and thus would not be part of the recommendation. He said that delvac 10w30 dino oil would also work just fine, but the 5w40 turbo clings better for improved protection, particularly after sitting for longer periods as mine will in the Ohio winter. He has 4 classics and that's what he uses, and he manages a team that sells about 20m gallons of oil into auto shops, ship yards, and industrial customers for gearboxes, so I guess if it's good enough for him, it's good enough for me.
Totally fair question - hopefully that helps explain my logic. Just trying to do what's best given current technology.
Old 02-05-2025, 08:37 PM   #44
FoodStamp
Any Updates to this thread? Im a pennzoil guy but being out of the parts trade for a while anything anyone would like to update? I have an original 350 1972 i need to change the fuel soaked oil and filter. Whats the latest and greatest? Anyone Like Schaeffers? This 350 starts and runs like 1972 so I dont want to harm it in anyway.
Thanks!
FoodStamp is offline   Reply With Quote
Old 02-05-2025, 08:54 PM   #45
binford
I use swepco in older engines.
Next on the list. shell rotella
I like 15-40 or 30
You can always switch to a 292 V 8 from a 3rd gen Chevy too
binford is offline   Reply With Quote
Old 02-05-2025, 09:00 PM   #46
FoodStamp
292 v8 ? isnt 292 v8 a ford y block? No sir!
Completely forgot about the L6 292 forgive me on that.
Old 02-05-2025, 09:06 PM   #47
IT Cowboy
IT Cowboy's Avatar
I have researched that the Lucas Hot Rod oil has the highest zinc levels and you can usually find a larger than stock filter with the same threads and gasket and it offers more filter surface area. Bobs The Oil guy forums are a wealth of knowledge and a huge trip down the rabbit hole on all things lubrication.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-05-2025, 10:04 PM   #48
'68OrangeSunshine
'68OrangeSunshine's Avatar
I like 15-40 or 30
GM calls the smallest LS series V8 from the GMT800s a 4.8 Liter.
The classic 292 L6 [RPO L25] was later called a 4.8L, but I've heard the V8 LS 4.8 called a 294 inch.
Possibly arbitrary.
Leo Santucci, author of the ''Chevrolet Inline Six Cylinder Power Manual,'' calls a 292 block [L25] that's been bored out to .060-over, a 301 C.I. So as not to be confused with the Ford 300 C.I. six cylinder. [Which is a reverse-engineered FoMoCo copy of the Chevy 292. It came out in 1965, 2 years after the Chevy 292 debuted. Even a mirror image: the carb and manifolds are on the passenger side, and the distributor is on the drivers side.
Old 02-06-2025, 11:52 AM   #49
Steeveedee
Steeveedee's Avatar
There are three filters available for the engine in your truck. A short one, one a little longer, and a 2-quart filter, which is generally installed on medium-duty and up engines. Don't use it on your truck with stock exhaust, as it will be almost touching the head pipe. At least it did on my truck. Also a 400 Cu In L47.
~Steven
Simi Valley, CA
Old 02-06-2025, 12:47 PM   #50
54blackhornet
54blackhornet's Avatar
I have a 307 in my 71 C/20. The engine is original with 52000 on it, it has never been opened up. I have used nothing but Dello 15/40.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
