Old 04-17-2023, 01:32 AM   #3676
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: What did you do to your truck today.The 3rd chapter
Went to replace the rear brake hose, crimped the snot out of the hard line(front to back) instead, so I started unbuttoning that line and making a new one.
Rust_never_sleeps is offline   Reply With Quote
Old 04-17-2023, 05:57 PM   #3677
72c20customcamper
72c20customcamper's Avatar
Started to cut up my new carpet to install the seat . Using an old set of brackets to mark it out
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-17-2023, 07:28 PM   #3678
zicc1835
zicc1835's Avatar
great idea thanks for sharing
zicc1835 is offline   Reply With Quote
Old 04-17-2023, 09:30 PM   #3679
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by pjmoreland View Post
If my memory serves me, there's a nice orange stepside cab in the Tucson area that already has a pair of bucket seats in it!!
Actually, that's a '69 Ford Thunderbird seat with bench seat, bucket backs and a fold-down center cushion in the Orange '68 C/10 Stepside. Also it was once electrically-adjustable. Not much swing with the Tank in the cab, though. I don't have the 6-axis switch connected bc it draws over 30 Amps. [Once I ran some handy 12/14 gauge brown wire to feed it. I forgot that was Fuseable Link line. After I adjusted the seat, the switch stuck in ON, and my ''brown wire'' cooked off. I grabbed it with my bare hand to yank it off, and branded a line across my left palm.]
The Jimmy needs new seats badly. The ones the PO put in are out of a Firebird/Camaro car from thre mid-80s. The foam was molded around the springs, and it's shot. Sharp pokey things pop up into one's posterior. And at the rear, the brackets are lag-bolted into 4''x 4'' blocks of wood. A head on collision will be fatal.
It's the '67 Suburban, I'm thinking of Buddy Buckets in. Shotgun rider could ''lay aft'' and check on the load, [or retrieve a cold one] from the back while underway.
Current stock '67 vintage bench seat is OK. Would be great after reupholstering.
Just kidding. Keep your seats. You found them. You build them. Only fair.
Old 04-17-2023, 09:52 PM   #3680
Casper42
Casper42's Avatar
Tilt column and 15" OE style wheel
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 04-18-2023, 01:32 AM   #3681
pjmoreland
pjmoreland's Avatar
The seats I'm working on had the foam molded around the springs and frames. Made it a chore to get the old foam off.
pjmoreland is offline   Reply With Quote
Old 04-19-2023, 03:19 PM   #3682
72c20customcamper
Seats in but I’m going to have my upholstery guy redo it this coming winter PUI sent me enough to redo the back which the pleats are not well done. I am liking the color though . Now I need to try to get some dye for the arm rest .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-19-2023, 03:37 PM   #3683
Grumpy old man
Grumpy old man's Avatar
This should work ,
https://www.ebay.com/itm/334152900903
Use an adhesion promotor like this , a few light coats goes a long way .
https://www.amazon.com/Bulldog-Adhes...a-571859709017
Old 04-19-2023, 05:11 PM   #3684
ghackett1
68 C10 Longbed
ghackett1's Avatar
Replaced a (2) month old T/A radial tire that went flat and tore up the sidewall. $165 gone!
ghackett1 is offline   Reply With Quote
Old 04-19-2023, 05:19 PM   #3685
Mendo70C20
Mendo70C20's Avatar
fuel tank relocation. And fixing other small things along the way.
1970 K20 long bed.
Mendo70C20 is offline   Reply With Quote
Old 04-19-2023, 06:04 PM   #3686
72c20customcamper
Originally Posted by Grumpy old man View Post
This should work ,
Thanks Grumpy
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-19-2023, 08:03 PM   #3687
zellway
zellway's Avatar
Originally Posted by 3757chevy View Post
What happened to spring? We go from cold and wind to hot and wind . [flip for you]
Thanks for that. I didn't notice it was flipped. It's often over 100 in April for me so a/c is a must.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 04-19-2023, 08:05 PM   #3688
zellway
zellway's Avatar
1970 K20 long bed.
That looks like a great fit. What is that tank from? It looks like the blazer tank. Outside of the notch in the frame what other mods did it take to fit so well?
Erik
Old 04-20-2023, 12:37 AM   #3689
Mendo70C20
Mendo70C20's Avatar
Yes it is a the blazer tank. Aside from the notch in the frame, nothing else to make it fit well. My frame is missing a cross brace though i think, so we welded in a 3.5" angle iron, and put it next to the tank on the cab side to stiffen and strengthen things up. These frame are soft and weak as it is. Welded in some metal to fill where the old filler neck was at as well. Paint should be this weekend. All new metal (angle iron, tank, tank straps etc..) all get shot with POR 15. Also installed a steering box brace to help make sure my frame doesn't tear at the steering box (common problem).
Old 04-21-2023, 02:26 AM   #3690
pjmoreland
pjmoreland's Avatar
Made a little progress on the seats I'm rebuilding. Reassembled the driver seat frame. Cleaned and painted the springs.
Old 04-21-2023, 09:55 AM   #3691
HalfBrit
Rerouted my fuel hardlines to behind the crossmember, to free up space for future exhaust work. And mocked up the ac/heater hose routing for the Vintage Air install
HalfBrit is offline   Reply With Quote
Old 04-21-2023, 10:34 AM   #3692
72c20customcamper
Finished the bed yesterday and took it out for a short drive . Everything works and no rattles was pleasantly surprised usually have to chase things down . Really need to change out the tires . Truck has 10 ply bias tires drives like a John Deere
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-21-2023, 11:59 AM   #3693
Grumpy old man
Don't I remember a post that you were considering just leaving it a patina truck ?
Old 04-21-2023, 12:20 PM   #3694
72c20customcamper
Got the letters done .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-21-2023, 12:23 PM   #3695
72c20customcamper
Maybe 3 years ago, but you are probably thinking of my other 68 that I’m not touching other than mechanically.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-21-2023, 12:24 PM   #3696
Steeveedee
Who Changed This?
Steeveedee's Avatar
That truck sure looks nice!
~Steven
Simi Valley, CA
Old 04-21-2023, 12:29 PM   #3697
72c20customcamper
Thanks it’s getting there . I should have the hood on in a few weeks and it’ll be about done. I have everything off a 72 c20 to put the disc brakes on it but that will be next winters project
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-21-2023, 03:27 PM   #3698
72c20customcamper
Glad I kept the 16 inch adapters . I just need to get two more PO1 caps the set I had were for 4 wheel drive so they have a big hole in two them . Always find a set at Carlisle truck show. I’m going to get new tires on the original 17 inch rims but these came off my 72 tires have about 5k on them .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-22-2023, 10:40 AM   #3699
pjmoreland
pjmoreland's Avatar
Assembled one of my seats last night. Glued the cover onto the foam so that it would follow the contours. These seats have no listing wires in the foam.
Old 04-22-2023, 10:55 AM   #3700
paul blair
Great Job on the seats PJ
paul blair is offline   Reply With Quote
