Location: 3,018 feet above the SoCal/Mojave Desert region.
Mounting reproduction / aftermarket door mirrors.
I picked these up this weekend. Always loved the way these look.
Finally got a pair. About where did you mount your mirrors? Thanks. |
![]() Join Date: Sep 2014
Re: Mounting reproduction / aftermarket door mirrors.
You can use the blue forum search at the top of the page and highlight 67-72chevytrucks.com. for past questions and posts.
Here is one that you’ll find: http://67-72chevytrucks.com/vboard/s...d.php?t=417037 Good luck
Sam 1972 C10 LWB, Hugger Orange/White 2025 GMC Sierra 1500 Elevation, Sterling Metalic |
Thanks. I would use the search function, but every time I use the search, it always clears and shows me nothing.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
This link should help. Found it through search. http://67-72chevytrucks.com/vboard/s...d.php?t=417037
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
68 C10 Longbed
I really like those mirrors also. I found an NOS pair on evil bay a few years ago and installed them on my 68. The passenger side mirror is located differently than the driver side. I had the original template from the NOS box but not sure I can find it anymore or I would shoot it over to you. Good luck. |
A little off the subject. I had my sport mirrors off for a few years. Trucks parked in the garage, I forever walked past the truck never hitting anything. Installed the mirrors and took the bark off my arm 3 times carrying in groceries. (so far) Sharp little boogers. Don't forget your backing plate inside the doors. Don't order the screws from Classic industries. They list the wrong screws at least for the original backing plates and the heads are incorrect. Good luck. The mirrors look great on a truck and you have lots of glass to see what they don't.
![]() Join Date: Dec 1999
The backing plates came in different flavors. Machine screws and pointed wood type screws. Had a pair of those on my 72 because they look nice, chose to go back to the DG4/D29 mirrors that came on it for better visibility in my rebuild. As mentioned the right mirror is located further back on the stock "sport mirrors".
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Managed to change mine from outside as didn't want to mess with door panel removal.
Thanks everybody for the replies. This all helps. I cringe anytime I have to drill, cut, shave, etc to any of my cars.
| Bookmarks |
