Tallest tire possible on stock steel rims?
I have a 72 k20 with a 4 inch lift. I would like to keep the classic steel rim look on my truck. The truck currently has 7.5 16t lt tires on it which is almost 32 inches tall. I would like to get tires a little taller close to 35 inches if possible. The guy at discount tires tells me I need new rims to get to 35 inches. Is there a tall skinny tire that will fit our stock steel rims?
![]() Join Date: Oct 2009
Re: Tallest tire possible on stock steel rims?
I'm not aware of anything that fits a stock-ish (i.e. relatively narrow) 16" truck steel wheel that can get you to 35, but others may know of some options. 255/85/16 is the tallest tire I've seen that can be safely mounted on a 6.5-8" steelie - just over 33". How wide are your wheels, inner lip to inner lip? that may help narrow down (or expand) your options.
![]() Join Date: Feb 2016
There are lots of choices for 16 inch rims. The problem may be your current rims may be too narrow for a taller wheel especially if you want to stay with a radial tire.
https://www.4wheelparts.com/b/tires-...gories%7Ctires What rims are you wanting to use?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
I was wanting to use the stock rims. But I have my eye on some ion or pro comps in case I can’t go big on stock rims
The Niner
![]() Join Date: Nov 2010
Pretty sure that 255/85/16 at 33" tall is the tallest you can go on a 16 x 7 rim. Anything taller than that would need to go 8" wide.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
Here's 3 tires I found that might work.
This is a military style tire and would need a tube inside of it. https://www.summitracing.com/parts/cok-71025 These other 2 are more what you're wanting. https://www.summitracing.com/parts/ict-sam-53 https://www.summitracing.com/parts/ict-ssr-41r |
nice finds roboticjunky!
Back in the day we would run 9.00 x 16s. Those were the equivalent size of a Q78 x 15, which was listed as 36.4 tall. Long gone are those tires, but here is a set from Coker tire, listed as Super Lug, 36.3 tall.
https://www.cokertire.com/tires/sta-...ly-900-16.html Here's another 9.00 x 16 tire listed. These are listed to fit a 6.5 x 16 rim size. https://www.stausaonline.com/tires/sta-super-traxion/ Both tires will fit a 5 - 6.5" wide rim. Last edited by MS66; 10-30-2023 at 09:31 PM. |
The 9.00-16 is that tire if you already have a lift for clearance. Has the tread pattern of the more common old school 7.50-16 that was very popular at one time.https://www.ebay.com/itm/33479329762...Bk9SR7Sl5OfwYg
i only have a 4 inch lift on the truck. im not sure the 36 inch tires will fit. i might have to stick with the 33's or just swap out the rims.
#11 | |
![]() Join Date: Jun 2019
#14 | |
#15 |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
33's will fit with no lift so you should be golden.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
#16 |
![]() Join Date: Dec 1999
Tire fitment is about clearance. With the skinny tire, rim and stock backspace there may be no issues while turning? If the tire does not fit in the wheel opening at full bottom the bump stops need to be lowered. For many that have pavement pounders (fine by me) clearance while turning at full bump is not really an issue.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#17 |
You can occasionally find a 9.00R16 Michelin military surplus tire. I ran a set on a first gen Cummins Dodge I had around 15 years ago. They are the XL tread pattern.
1970 C10 l/b 292/4spd Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062 |
