11-07-2023, 05:28 PM | #26 |
Re: 67 C20 with 283 w/3 speed on the floor keeps killing starters.
I have long tube headers and noticed increased dragging and hard starts due to heat soak with my second Delco Remy OEM-style reman starter, so this time I installed a PowerMaster 9112 a week or two ago. Made in USA. It's half the weight, smaller size for more air flow, and has twice the power of the OEM starter. Love it. It came with two bolts and shims (didn't need the shims). I did have to clock the solenoid one position to clear the block as it was shipped in the straight-up position. The higher torque fires up my SBC more quickly and my heat soak issues are gone.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. Last edited by tim_mc; 11-07-2023 at 05:48 PM. |
11-07-2023, 06:38 PM | #27 | |
Not knocking DB just my experience with them
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
11-07-2023, 06:40 PM | #28 | |
11-07-2023, 07:11 PM | #29 |
Good idea Mark - I wish I would have thought of that. Oh well - it's installed and I shouldn't have to worry about starts for a while.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
11-08-2023, 11:49 AM | #30 |
Quick update:
Went out to yank the starter and found the main power wire broken. Had to pick up a replacement wire, since the existing wire is old, stiff, and covered in oil (intake leaks like a bastard) and I'll report back to see if that's the actual issue. Even if it DOES solve the issue, I think I'm going to pull it to check for block mounting options to run a mini with a heat shield. (maybe I'll wrap the header, too) Thanks for all the help, fellas! |
11-11-2023, 01:04 AM | #31 | |
I've got a stock warranty replacement for now, but when this one dies, I'll step up to a new, smaller unit. What a pain... |
11-11-2023, 01:28 AM | #32 |
You could probably stick just about any old piece of metal between the exhaust and starter to make a heat shield, just bolt or clamp it on there or use baling wire to hold it in place. A coffee can treated with some BBQ high heat spray paint or exhaust manifold paint brushed on from a can so it lasts a few years would probably be pretty good. I made a heat shield for my Mazda Tribute and it worked great. Roof flashing also works great, it is particularly good because it's galvanized. If not abused the starter should last a very long time.
11-11-2023, 08:16 AM | #33 | |
Might as wwell put a heat shield on it now.... or Go with a Powermaster and never look back. But I would still put a heat shield on the header, or, over the starter to protect the investment. Stuff ain't cheap. https://www.speedwaymotors.com/Power...vy,229562.html |
11-11-2023, 09:19 AM | #34 |
I’ve always had problems with my 72every starter was too far away from the flexplate . I had been shimming the outside bolt to swing it into the ring gear . This time after putting in the new flexplate I decided to end it once and for all . I milled the mount on the starter and kept putting it in and checking my clearance. I got it to .025 without shims but I put a shim in to bring it to .030 . Powermaster calls for between .020 -.035
