Old 11-14-2023, 05:59 PM   #1
cgster
Under bed gas tank/bed to frame bolt holes
I have moved my gas tank to under the bed. I currently do not have the bed on the truck but looks like I may run into the problem of not being able to get the rear bed bolts/to Frame installed with the gas tank sitting underneath the bed, it looks like those holes will be hard to get to when the bed goes on. Anyone had an issue with this? Thanks.
cgster is offline   Reply With Quote
Old 11-14-2023, 06:07 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Under bed gas tank/bed to frame bolt holes
Yes. With my Boyd's welding tank, I have to drop it to access the bed bolts.
I got the Boyd's mounting kit where you put a threaded bar in the frame rail and the tank has bolts that go in from the bottom to mount the tank.
I use some replace those bolts with 6 inch long ones and can drop the tank down enough to access the bed bolts...
Jason Banks is offline   Reply With Quote
