Old 12-15-2023, 12:52 PM   #1
zen.C10
Oil cap wtf?
My truck is new'ish to me, and I thought I worked through most of quirks but I came across a new one over the weekend. I went to top off my oil and realized the oil cap won't come off - it just spins in place.
I know I can add oil through the PCV, but what's the deal with the cap? Shouldn't I be able to remove it? Am I missing something or is this a sign of a bigger issue?
I'll probably take the valve cover off to see what's holding the cap in place, but I figured I'd ask you all before I go that route.
zen.C10 is offline   Reply With Quote
Old 12-15-2023, 01:09 PM   #2
Casper42
Casper42's Avatar
Re: Oil cap wtf?
sounds odd to me. first, I'd pull up and turn at the same time - you should be able to feel where the release points are. Once identified, pry up gently
'72 C10 Cheyenne SWB North Carolina kept for 50 years, 75k original miles, Medium/Hawaiian Blue paint, 3 owners - one for 40 years & garaged kept. Original: sheetmetal, undercarriage, moldings, glass, immaculate unrestored bed.
New - rebuilt engine at 65k in 2015, one frame-on respray in 2010, front bumper, blue houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 12-15-2023, 01:11 PM   #3
kwmech
Re: Oil cap wtf?
Some oil caps will not twist off. They are like a big rubber plug that is flared out at the bottom a little to keep it in place. They can be a real bugger when the rubber starts to get hard
Old 12-15-2023, 01:15 PM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Oil cap wtf?
1971-72 generally used the push in/pull out rubber plug style oil cap. The 1967-70 used a twist cap.
Old 12-15-2023, 03:47 PM   #5
54blackhornet
54blackhornet's Avatar
Re: Oil cap wtf?
I see this is your first post, welcome to our world. Get a tiny flat screwdriver and gently insert it underneath the plug and pry up. They are at times difficult to remove. Do it a few times and you’ll figure it out…
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-15-2023, 03:54 PM   #6
zen.C10
Re: Oil cap wtf?
Thanks, guys. I'll keep at it and see if I can finesse it out without chewing it up,. The plug itself is hard like plastic, so I can't tell if it's rubber because the previous owner painted it to match the orange valve covers. It also seems brittle, so I'm wondering if the paint or clear coat reacted with the rubber and the previous owner just left it alone.
Here's a couple of pics in case that's helpful.
Old 12-15-2023, 04:25 PM   #7
Myself
Re: Oil cap wtf?
Sure looks like the plain Jane push in style to me. The rubber is slightly flared out at the bottom, that's what holds them in. When they get old the rubber becomes like hard plastic. You're probably going to have to just pry it out.
Myself is offline   Reply With Quote
Old 12-15-2023, 04:44 PM   #8
7tee
7tee's Avatar
Re: Oil cap wtf?
Why not pull the PCV out and boot if you need to add oil...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 12-15-2023, 04:51 PM   #9
dmb
Re: Oil cap wtf?
Just buy a new oil cap, I expect you can pick one up at any parts place or
https://www.ebay.com/itm/18599941619...Bk9SR9zY7vONYw
dmb is offline   Reply With Quote
Old 12-15-2023, 04:54 PM   #10
dmb
Re: Oil cap wtf?
if you get the old one out, it may not go back
Old 12-15-2023, 06:56 PM   #11
howzzzit
howzzzit's Avatar
Re: Oil cap wtf?
Are those covers on the right sides? Maybe flipped? Wouldn't think they would put the oil cap under the a/c bracket. On my old covers the oil fill was on the drivers side closest to the firewall. It had a push in grommet that accepted the tall fill tube. Probably the same grommet for just a push in oil cap. Wish I still had the setup. I will if I ever find any stock valve covers. Also, you can buy new grommets. PS if you really hate the valve covers I'll give you my address. Such a nice guy.
howzzzit is offline   Reply With Quote
Old 12-17-2023, 08:12 AM   #12
ghackett1
68 C10 Longbed
ghackett1's Avatar
Re: Oil cap wtf?
FWIW:
Yep those are the rubber push in style. Just remember when they get old and brittle the can break apart when trying to pry out. If this happens be sure no pieces fall into the valve cover, if pieces fall in you should remove the valve cover and get the hard plastic pieces out that will be laying around your rocker arms.
ghackett1 is offline   Reply With Quote
