![]() Join Date: Jan 2016
Looking for NOS ignition switch and wire connector
I have been looking for NOS ignition switch and connector, found many but none said NOS or OEM. I found plenty cheep ones probably made in china. Any one here know where to buy the best quality available? Pic of what I am working on. I wonder if this is the off idle lag that happened some times? Thanks for any information! 1970 K/10
Re: Looking for NOS ignition switch and wire connector
I can't remember if it was M&H or AAC wiring but, one of them sells connectors separately. I've seen both of their factory style replacement harnesses and they don't use the flexible Chinese ones.
Here is a thread I started on ignition switch failures. Currently I am of the opinion that a cleaned and inspected original or at least a replacement manufactured in the 70's is the best option. If no other option then reforming the contact shape on a new one may help curtail early failures. I'm still using the Echlind replacement at present. But I should pull it out and do a inspection. https://67-72chevytrucks.com/vboard/...d.php?t=818861
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Jun 2022
not to derail the convo, but how does the switch cause off-idle lag?
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
I'm not sure it could but I've learned over the decades that I should never state something as an absolute. Oh I just did it again.
![]() I will say there are a lot of other causes of an off idle stumble that I would look at first before I suspected a bad ignition switch.
Always true....except when it isn't ;-)
#7 | |
![]() ![]() Join Date: Jul 2003
Look on EBAY for both.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
![]() Join Date: Jul 2000
I've used at least four switches that came with wiring harness kits. I don't know where they were made, but I've never had a problem with any of them. In fact, the switches in some of the American Autowire kits can handle more current than OEM, for example their 55-57 Chevy kit. Just finished up installing an AAW harness on my 69, and the included switch seemed just fine to me. Very stout feeling when switched through various positions.
Just looked for one in the AC Delco catalog, but they don't show it. Strange because that switch was probably used in most GM cars and trucks back then. From what I see that's available, I would probably go with Standard Motor Products US84 (not the cheaper US84T). https://www.rockauto.com/en/moreinfo...=4700&jsn=1240
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#10 | |
![]() Join Date: Feb 2015
This may be what you are looking for?
Original GM, made in USA ignition switch. Can take another pic if necessary. I have a few - stashed for years. Message me if you want one. If that's illegal, I'll have to buy in to post in for sale area. LMK |
That's pretty cool!
Thanks for this information, I will PM you.
And and old OEM connector probably 52 yrs old seams to be near perfect.
| Bookmarks |
