Old 12-25-2023, 11:40 PM   #1
Hotcorner
Hotcorner's Avatar
Fuel Pump Question
My fuel pump took a crap and I was going to install one from O’Reilly’s and mentioned it to a buddy and he offered up this NIB Carter. It’s supposedly a high flow pump and seems much more substantial than they new one from O O O O’Reilly. I’ll have to buy a few new fittings for it to make it work with my plumbing, but is there any reason NOT to use the Carter?
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 12-26-2023, 12:49 AM   #2
jessemthompson
Re: Fuel Pump Question
I would figure out what’s cheaper, the fittings you need to make the Carter work, or the fuel pump from oreillys. Whichever saves $$$ would be the route I’d take. Either way works.
jessemthompson is offline   Reply With Quote
Old 12-26-2023, 10:37 AM   #3
Sheepdip
Sheepdip's Avatar
Not sure as to what "New Fittings" you require but that Carter is clockable.
Sheepdip is offline   Reply With Quote
Old 12-26-2023, 12:48 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I put this one on my truck in 2021 when still had the original 350 and went to the rear mounted tank. I replaced the engine with a redone small block 400 last summer (2022) and it working fine. I guess not cheap as I just looked and its 75.00 US now but I'd rather have something that will do the job long term that worry about 20/30 bucks more for something.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-26-2023, 12:58 PM   #5
54blackhornet
54blackhornet's Avatar
I recently replaced the pump on my 307 with one I got at Napa. Threads were stripped inside the outlet port. Hard line would not screw into it. Replacement was from CarQuest was cheaper and worked perfect. I used a stud instead of a blot on the inside mounting to make installation easier. Helps align the pump while tightening it up.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-26-2023, 01:29 PM   #6
Wrenchbender Ret
It depends on how old it is. Some old pumps had materials that were not compatible with fuels with ethanol in them. Some old pumps can have the diaphragm dried out.
George
Wrenchbender Ret is offline   Reply With Quote
Old 12-26-2023, 03:20 PM   #7
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Fuel Pump Question
I am running NOS AC fuel pumps on all of my vintage GM vehicles. I have non-ethanol fuel in this area for them. No failures from any of them.
I have more trust in a 40-50 year old US made pump than a brand new Chyna pump.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 12-27-2023, 09:40 AM   #8
HO455
HO455's Avatar
I've used those Carters several times over the years with no issues. Carter used to sell replacement diaphragm kits for them. As long as the pivot wasn't worn out you could rebuild them. We have one on my buddies GTO that runs 11.20's.
RIP Bob Parks.
Old 12-28-2023, 04:50 PM   #9
68 P.O.S.
Fuel presure. The pump's pressure vs the carb's recommended operating pressure. You need to find out those values. If its too much pressure for the carb, it'll flood and run like crap.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-28-2023, 05:03 PM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
We need to know what type engine and what carburetor you're running?
That Carter pump will be higher quality than an off-the-shelf [asian] fuel pump from ORAP.
Old 12-28-2023, 07:42 PM   #11
HO455
HO455's Avatar
That Carter pump was designed for carburetors. The only concern in regards to fuel pressure would be if your running a pressure sensitive carb like a 1406 Edelbrock then you MIGHT need to install a pressure regulator. They are high volume not high pressure pumps.
No reason not to run it, especially if it is low priced.
Plus it's rebuildable! Pretty sure this is the kit.
https://www.summitracing.com/parts/crt-888562
RIP Bob Parks.
Old 12-30-2023, 05:52 PM   #12
72SB
Got a $19 Carter from Summit. Works perfect with my Eddy carb. FP gauge says 5.5 PSI. All good
72SB is offline   Reply With Quote
Old 12-30-2023, 10:25 PM   #13
Hotcorner
Hotcorner's Avatar
Agree 100%. I want to install the Carter unless there’s a reason not to use it. Has nothing to do with the cost.
1969 GMC K25
Old 12-30-2023, 10:27 PM   #14
Hotcorner
Hotcorner's Avatar
I have an Edelbrock. I’ll need to check again on the model number.
1969 GMC K25
Old 12-30-2023, 10:31 PM   #15
Hotcorner
Hotcorner's Avatar
It’s a stock 350. I’ll check the model # on the Edelbrock.
1969 GMC K25
Old 12-31-2023, 12:50 AM   #16
'68OrangeSunshine
Then you should be fine, as the Edelbrock Performer is essentially the same as a Carter AFB. I run a Carter AFB 9635, 600CFM. [It's about the same as an EDL 1405.]
An L6 would have a fuel pump that's ''inverted'' from the V8 orientation. I don't know if flipping a fuel pump has any effect on its operation. But I've always used the pump specified for each engine type.
Old 12-31-2023, 10:12 AM   #17
68 P.O.S.
So, once again, check those pressures. Edelbrock recommends a fuel pressure regulator set to 5.5 psi, or their fuel pump which runs at 6 psi.
