#76 |
Re: Shifting at high RPM
#77 | |
The only connector is coming from the 4x4 firewall to the top left side, I think it’s for 4x4 engagement and light, See pictures
1972 GMC Sierra C2500, V8-350 1986 GMC Sierra C2500, V8-454 1986 GMC Sierra C2500, V8-LS1 1986 GMC Sierra K2500, V8-350 1987 GMC Sierra R3500, V8-454 1997 GMC Sierra K2500, V8-454 |
#78 | |
Hopefully I can load it
#79 |
Pictures are attached,
The website will not allow me to upload more than 2, or it keeps say your message is toooooo short
#80 |
#81 |
I did disconnected it, as I mentioned before, nothing.
#82 |
Any ideas?
I’m not getting any luck with this trans. I managed to get me a vacuum gauge but I’m not sure what to do or to look for? Any suggestions
#83 | |
#84 | |
#85 |
#86 |
Yes I did and nothing still will not shift from 1st gear
#87 |
I see, so to avoid any spillage I should start the truck for few minutes
#88 |
What if anything does the transmission do? What happens when you try to drive it, Forward shifter in D? 2nd? 1st? What happens with shifter in reverse?
#89 | |
The only issue is shifting from 1st to 2ed. I’m picking my brain on what happens from before painting the truck and replacing the valve stems, to now. No one worked on the trans, or the manifold, only the valves.
#90 |
When it is in Drive or 2nd when you start out does it ever shift or does it just stay in 1st gear? When in Reverse it moves normally?
#91 |
When you removed vacum modulator did you take the valve out behind the modulator? Did it move freely if you took it out and replaced it?
#92 | |
In reverse it’s normal, I did try in 2ed but didn’t notice it shifted I’ll check and see Wow In 2ed it did shift from 1 to 2 so smoothly I barely notice it, I put it in D and I think it shifted from 1 to 2, Tomorrow I’ll do full test and I’ll update you
1972 GMC Sierra C2500, V8-350 1986 GMC Sierra C2500, V8-454 1986 GMC Sierra C2500, V8-LS1 1986 GMC Sierra K2500, V8-350 1987 GMC Sierra R3500, V8-454 1997 GMC Sierra K2500, V8-454 Last edited by Captain J; 01-04-2024 at 01:46 PM. |
#93 | |
Unless I’m not doing it correctly ( using a magnet), First time no oil came out just few drops, second time about 2ltr came gushing out.
#94 |
Greetings to you all for helping out in my truck gear issue.
Update I test drive the truck last night, and it shifts in all gears, I don’t know what happened, but it’s working fine, Again, thank you all for your suggestions and recommendations, I wish I knew what was wrong with the tranny.
#95 |
![]() Join Date: Mar 2003
Probably a piece of that silicone
#96 |
I have no clue, but it’s working now and that’s important.
Maybe the gremlins were there
#97 |
I figured it would be something simple lol. It probable was the sticking modulator valve. They are supposed to slide out easily. I didn't think we were going to get any further with the diagnosis without an actual vacuum reading at the modulator. Happy ending anyway.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#98 | |
Regarding the vacuum readings, what is the correct reading in psi? Yeah happy ending
#99 |
manifold vacuum at the end of the hose 14-15 inches ----ish
#100 |
Ok, I’ll check
| Bookmarks |
