Old 01-06-2024, 04:19 PM   #20
MySons68C20
MySons68C20's Avatar
Re: Which Headers?
Originally Posted by MikeB View Post
Over the years I have learned that exhaust ports on aftermarket heads are sometimes raised higher than those on stock 60s-80s heads, and the header mounting surfaces can stick out farther (making engine width wider). One or both of those issues apply to Dart Iron Eagles, Brodix IK-series, and even GM Vortec heads I've used over the years. Oh yeah, I forgot valve cover gasket "rails" that are raised 1/2" or so to reduce leaks. That can sometime cause a valve cover to interfere with with an alternator or AC compressor.
I've actually had to re-fab compressor brackets, notch frame rails for header tubes, and raise exhaust pipes where they connect to header collectors. And some heads will have spark plug holes in slightly different locations from stock, Vortecs being a good example. But other than that...
My biggest concern right now is how low the Hookers will hang below the frame.
Since I have mid length right now I know the connection to the header will change.
I'm hoping G will take a pic just to confirm.
I have no A/c to worry about and have about 3/4"+ frame clearance with the current Heddmans.
Thanks for the input it really helps!
MySons68C20 is offline   Reply With Quote
