Old 01-11-2024, 11:40 AM   #1
Toro
Toro's Avatar
Fuse panel - new labels
Has anyone made new labels for their fuse panel? The original factory labels have faded/worn off on a majority of mine. It looks like the originals were painted on silkscreened on. It's very narrow on the edges, and I'm not sure what labels would even fit. Better solution would probably be one big label/sticker that included fuse cut-outs that could go over the entire face. Thanks for any input.
Toro is offline   Reply With Quote
Old 01-11-2024, 12:27 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Fuse panel - new labels
Shame those made for a new harness aren't available, but I haven't done the research. Option to do that with labels and a printer. Or that big label. Or leave it alone Can always put an illustration in plastic sheet, keep it in the glove box.
https://www.loadzalabels.com/products/black-stickers
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-11-2024, 05:23 PM   #3
LS short box
Take pic of the fuse block and take it to a local graphic shop and see if they can help. If they can make you new labels have them do a 1/2 dozen sets. Use one set for your project and then sell the others to folks that are in the same boat as you are with a bit of a mark up.
