#36 |
Re: Proportioning Valve Keeps Tripping?
Change your pedal ratio.
Check where your connection pushrod is on the brake pedal and Drill a hole 1 1/2 inches lower. Attack the pushrod there and test. Your pedal ratio should be close to 4 to 1 then. |
| Bookmarks |
| Tags |
| bleeding, brake light, brakes, proportioning valve |
