Old 04-18-2024, 11:35 PM   #37
Sheepdip
Sheepdip's Avatar
Re: Proportioning Valve Keeps Tripping?
Can you post pic's of your brake calipers as you have them installed? I'm just shooting in the dark here....on a thread a while back there was a situation as yours where the owner kept stating the bleeders were on top, and they where.. But they were not on top of the piston bore to remove all the air. He finally rotated or swapped the brackets which put the bleeder actually on top and problem solved.
Sheepdip is offline   Reply With Quote
bleeding, brake light, brakes, proportioning valve
