Old 04-22-2024, 10:20 AM   #101
loudchevy
Active Member
loudchevy's Avatar
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
I wasn't gonna do anything with the bed for a while, but I needed a change of scenery from bodywork. It's only going to get warmer from here out in Phx (90*ish in the garage already) so I decided to break down the bed so I can get it cleaned up and shortened. I only got (4) carriage bolts to come off cleanly. The rest took a combination of drilling, grinding, punches, and a BFH. The best approach was cutting a slot in the top to use a flathead screwdriver to hold the bolt and impact the nut off from the bottom, but that didn't always work out as some the bolts couldn't get a cutoff wheel on them. Overall, it took around 5 hours to break the whole bed down. If anyone needs the fiberglass toolbox insert that comes with the LWB toolbox option, hit me. The one I removed is in good shape.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 04-22-2024, 10:27 AM   #102
loudchevy
Active Member
loudchevy's Avatar
Couple more pics....I also removed the stake pockets from the driver's side panel. I was going to cover the openings on the top rails anyways. The passenger side panel is banged up around the wheel well and it has the giant opening from the toolbox, so I'm not going to cut that side down. I'll be looking for a LWB or even better SWB panel to use in its place. The crud pile from the bottom of the bed was smaller than I thought it would be. At least it's a dry heat, right?
Scott
2003 Tahoe Stock
Old 04-22-2024, 10:44 AM   #103
raggedjim
raggedjim's Avatar
Nice work, it always amazes me how much crap can be hiding in the nooks and crannys!
In western KY it's 55 with 43% humidity!
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 04-23-2024, 08:12 AM   #104
Chaparralman1974
Chaparralman1974's Avatar
Great work Scott! Tearing down the bed is more work than it looks. It took me all day to do mine doing the same thing you did.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 04-23-2024, 10:45 AM   #105
loudchevy
Active Member
loudchevy's Avatar
Rg
Clay
Thanks Gents.
Scott
2003 Tahoe Stock
Old 05-20-2024, 09:48 AM   #106
loudchevy
Active Member
loudchevy's Avatar
Life gets in the way and truck projects get moved to the back burner just like everyone else here knows. The boy and I finally got around to taking apart the cab, fenders, hood, and doors into their individual pieces for what I hope is the last time. I spent all day Saturday prepping the garage for sealing and high build primer on the doors and fenders to be ready to spray on Sunday. I wanted to be able to spray both sides of the doors at the same time, so I built up some redneck panel holders out of my sawhorses with some long 2x4's lol.
First coat was a reduced epoxy primer layer to seal up the exposed metal and filler. I waited 30 mins and then sprayed the 1st coat of the Eastwood 2K Urethane with a little bit of reducer on all 4 pieces, waited another 15 mins, and did the same mixture for the 2nd coat. The final coat of Urethane was straight 4:1 with no reducer. It was super nice spraying the high build primer on the panels. I had zero issues using my cheap Amazon A610 gun with the 1.7 tip. It's super rewarding to see the panels with their final primer sprayed on. Are they 100% prefect and show quality, no, but I did all the work myself and learned a **** ton in the process for which I'm very happy about.
My hood and cab still need some attention. When taking apart the truck I noticed a couple of places on the hood that I missed putting filler on. The cab still needs to be seam sealed on the drip rail and the other joints around the door frames, and front windshield. I'm going to try and get the hood and cab sanded and ready for the same sealing/Urethane spraying this weekend.
Scott
2003 Tahoe Stock
Old 05-20-2024, 11:31 AM   #107
Chaparralman1974
That thing is looking great Scott! I am going to go ahead and order the same gun from Amazon. My HF purple gun is ok, but I want something just a little bit better. When do you think you will lay down the color?
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 05-20-2024, 01:26 PM   #108
loudchevy
Active Member
loudchevy's Avatar
Clay
Thanks Clay, Not sure when color is gonna get sprayed. We still need to pick a color . After this long 3 day weekend, my next couple of weeks are busy so it might be a little bit longer than I would like to get back working on the truck.
Scott
2003 Tahoe Stock
Old 05-20-2024, 03:29 PM   #109
rodstored-72
chevy truck fan
rodstored-72's Avatar
scott, progress is looking really nice & moving along, thanks for keeping us posted i think you and chaprralman are moving nicely along...
rodstored-72 is offline   Reply With Quote
Old 05-20-2024, 10:07 PM   #110
zicc1835
zicc1835's Avatar
well good to hear your back in it.... lookin good
zicc1835 is offline   Reply With Quote
Old 05-21-2024, 12:20 PM   #111
loudchevy
Active Member
loudchevy's Avatar
Thanks! Chaparralman1974 and I like to text each other about how much we enjoy doing bodywork
Scott
2003 Tahoe Stock
Old 05-21-2024, 12:21 PM   #112
loudchevy
Active Member
loudchevy's Avatar
Thank you, Sir
Scott
2003 Tahoe Stock
Old 05-22-2024, 11:48 PM   #113
loudchevy
Active Member
loudchevy's Avatar
I spent the evening sanding the entire cab and seam sealed the door jambs and front windshield seams. Tomorrow evening the drip rail will get some self-leveling sealer, I hope I don't mess it up! Also need to sand down the entire hood and put some filler in a couple of places. Friday evening will be garage setup/prep for spraying. Trying to stay on pace to spray the cab and hood in Urethane on Saturday morning.
Scott
2003 Tahoe Stock
Old 05-24-2024, 11:05 AM   #114
loudchevy
Active Member
loudchevy's Avatar
I got the hood sanded, filler applied where needed and the drip rail filled with self-leveling seam sealer last night. The sealer turned out ok, It dried on me quicker than I thought it would. The tape I laid down was just under the sealer edge and when I pulled it there wasn't a smooth transition, so I put more sealer in the gap and it dried a little wavy. I hope the high build will help conceal some of it. Maybe I can get a light sanding on it to help smooth it out? I hope it looks ok when it's all done as I'm tall and will be able to see it every time I get in the truck to drive.
Garage getting prep'd tonight for spraying tomorrow morning
Scott
2003 Tahoe Stock
Old 05-24-2024, 12:19 PM   #115
Chaparralman1974
Looks great Scott...as always!!
I think that you can sand out the seam sealer. I also watched a video where a guy used a folded over scuff pad to help work the seam sealer. I think you can also dip a spoon or something into acetone to prevent sticking as you work it. But then again, you saw the abortion of a job I did to the underside of my cab, so don't trust me on it. LOL!!!
I am really lagging behind you....I have to put my a$$ into gear! :-)
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 05-24-2024, 12:20 PM   #116
Chaparralman1974
Scott, one quick question....for the drip rails that are vertical on the back of the doors...do you use the self leveling stuff there, or would it run down due to gravity? I am hoping to get to this stage at some point soon.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 05-24-2024, 01:25 PM   #117
loudchevy
Active Member
loudchevy's Avatar
Clay
Thanks Clay!
I didn't mention or show that I first put a skim coat of regular seam sealer along the whole drip rail to really get it pressed down into all the seams/joints. Once that layer setup for 15 mins, I re-taped everything and did self-leveling along the whole rail, even the vertical ends. I let gravity pull down on the sealer adding a little bit at a time until I felt there was enough to make it all the way down to the bottom of the rail. I had a little tape blocker/plug at the bottom of the vertical rail to catch any extra, but I actually nailed it pretty close and there was very little sealer to catch. I made sure the front of my cab was facing the house so the slope of the garage floor was heading downhill to the rear of the cab, it was just enough slope for the self-leveling seal to do it's thing. I used the tip of the applicator to spread out the fluid so it got all the areas covered (between rail edge and cab sheet metal) and gravity smoothed out the rest.
It's still a little tacky this morning so I don't want to touch it yet. I'm NOT going to let my impatience get the best of me, I'll wait until tomorrow morning to mess around with it if I even do anything to it.
Scott
2003 Tahoe Stock
Old 05-24-2024, 01:51 PM   #118
cj847
cj847's Avatar
On mine (just recently done) I used regular seam sealer on the vertical and self leveling on the horizontal.
I had some spots where the edge of the sealer was not a good straight line. After it dried. I sanded it until I had a consistent transition from sealer to roof. I think I used 80 and 180 folded over a paint stick or a piece of steel to get a sharp edge.
It's a bit of a thankless job as noone is going to see it, but it bugged the heck out of me.
PS> that stuff is no fun to sand.
cj847 is offline   Reply With Quote
Old 05-24-2024, 01:57 PM   #119
loudchevy
Active Member
loudchevy's Avatar
Thanks for the reply.
How long did it take to fully dry before you sanded it?
Scott
2003 Tahoe Stock
Old 05-24-2024, 04:51 PM   #120
cj847
cj847's Avatar
In my case I used the 3M stuff. It's an epoxy and was hard the next day, but I didn't sand it until about day 3 I think.
Old 05-28-2024, 10:44 AM   #121
loudchevy
Active Member
loudchevy's Avatar
Productive 3 day weekend. The cab, hood, cowl, and glove box door got their Urethane primer. Feels good to have the cab forward completed on this step. I left the floor, rear lower wall, behind the dash, and A-pillar side walls in Epoxy primer. My plan is to Raptor Line those areas. I can see a few dings and pin holes that I missed filling before this coat, so I'll need to take care of them. The boy and I also need to pick a final color too.
Life gets busy the next few weeks, so zero progress will happen on the body. It will give the primer awhile longer to fully harden. My rear patio looks like a C10 bomb blew up right now. The frame is back in the garage and It's about time to start working on something other than bodywork.
Scott
2003 Tahoe Stock
Old 06-13-2024, 06:17 PM   #122
loudchevy
Active Member
loudchevy's Avatar
Working on something other than bodywork has been a great change of pace. I started cleaning up the 454 the last few evenings. I was going to swap out the chrome oil pan that I never really cared for, but decided against it. It wasn't leaking so I told the "might as well" devil on my shoulder to piss off. I scrubbed the oil pan, block, heads, and intake down with some brushes and degreaser. It was pretty easy with all the practice of sanding of body panels I have been doing as of late. I scuffed up the old red paint, wiped it down, taped up everything and sprayed a few coats of Eastwood Chevy Orange high temp ceramic engine paint. It looks great against the alum heads and chrome oil pan.
Next up is to clean up the water pump and the rest of my serpentine accessories. I still need to buff out the alum valve covers at some point to really tie it all together.
Once the paint is dry on the block, I'll bolt it up to the 700R4 and get them sitting between the frame rails by the end of the weekend. I bought a set of POL engine mount brackets with some new poly motor mounts and a new tubular transmission xmember with a poly mount a while ago, so I have those to install as well. I want to test fit my long tube headers and see if they will work on the C10 frame. They fit perfect on my 85' K5 frame with this 454, so I hope this will be the same.
I would also like to drop the primered cab back on the frame just to make sure everything is good before (at some point) spraying some color on the body.
Scott
2003 Tahoe Stock
Old 06-13-2024, 06:32 PM   #123
Shifty One
Shifty One's Avatar
That's a fantastic place to hide a vintage Milodon pan....
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 06-13-2024, 07:56 PM   #124
clay68c10
clay68c10's Avatar
I love some Big Block torque! I bet that’s a strong runner, and it looks great.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-14-2024, 10:00 AM   #125
loudchevy
Active Member
loudchevy's Avatar
HA! I have too many other things to buy that are needed more than an upgrade at this point....something like a Boyd Welding gas tank
Big Block torque is the best! It's a strong engine. It would move my lifted K5 with 37" tires and 4:56 gears too well.
Scott
2003 Tahoe Stock
