#4926 |
![]() ![]() Join Date: Mar 2016
Re: What did you do to your truck today.The 3rd chapter
double post
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#4927 | ||
#4928 |
![]() Join Date: Oct 2012
Finished painting the cab, cowl, fenders, doors, and hood this past weekend.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#4929 | |
![]() Join Date: Feb 2002
#4930 |
![]() Join Date: Aug 2015
Today I applied what I hope is the last coat of paint on the 67 steering wheel I restored. I started working on it 4 years ago but got side tracked working higher priority projects.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke Lariat 2007 BMW X3 2023 BMW X3 M-Sport 2020 BMW 540xi M-Sport 1995 Harley FLSTC |
#4931 |
#4932 |
Thanks, the process isn't difficult but involves a lot of sanding. Always a risk when not having a paint booth, but there was no wind this morning so I went for it.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke Lariat 2007 BMW X3 2023 BMW X3 M-Sport 2020 BMW 540xi M-Sport 1995 Harley FLSTC Last edited by ohboy321; 07-09-2024 at 06:18 PM. |
#4933 |
I need to do that to my '68 Wheel. I tried to get the OE Stock color spray paint FAWN, but I'll have to settle for Nissan Driftwood Sand.
#4934 |
Who Changed This?
![]() Join Date: Jan 2013
Just remember that it's a paint chip in a catalog and not actually a furriner color!
#4935 |
Loading up to go to Tennessee leaving in the morning
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#4936 |
Mr. Cheyenne
![]() Join Date: Jun 2020
For a bit now my battery meter hasn't moved, finally bugged me enough to check the fuses, when I pulled the driver's side apart the glass separated. I stuck in a normal one in (which is way to long) but that allowed the battery meter to come back alive.
I wanted to get Littelfuse SFE4BP SFE, but got Bussmann Division SFE-4 Auto because they'll come in tomorrow (via Amazon). Hopefully it will fit properly! After that, I'll not drive or see my truck for awhile - which makes me sad. I'm having to move to Atlanta, Ga on Saturday to keep my position at WarnerBros. Discovery (my remote work status was revoked) and I must report to the campus there. My youngest will be keeping up the house here in Texas, while I hunker down in a little apartment. Kind of sucks but I am trying to see it as an adventure. After being here in my home for nearly 25 years and twice as long in Texas, it surely will be different. Here's the truck, nicely tucked with her cover on to keep the dust off while I am away. See you labor day or perhaps Thanksgiving Good 'O Truck! :'(
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#4937 |
![]() Join Date: Mar 2021
Good luck with everything Richard, that sux
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
#4938 |
![]() Join Date: Mar 2011
looks real good
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#4939 |
Mr. Cheyenne
These Bussmann Division SFE-4 Auto fit perfectly! I recommend these and I love the little case, reminds me of the old days getting little boxes of fuses.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 07-12-2024 at 08:36 PM. |
#4940 |
Today I installed an alternator bracket that I lengthened and modified to work with my M/T valve covers. I made a temporary one a couple of years ago until I had a way to heat/bent metal to match the curve needed to clear the alternator. This was a good project to justify an oxy/acetylene torch for the garage.
#4941 | |
![]() Join Date: Sep 2014
![]() It’s really something how those two fuses cover a lot of territory of the truck. The ole glass fuses and OE fuse panel are still going strong on my 72’ ![]() Now back to the thread: I ordered a tri fold tonneau cover for my 8ft C10 bed.
Sam 1972 C10 LWB 2020 Z71 Tahoe |
#4942 |
Spal 16 inch pusher fan came today . This is for the 72 even though I put a new Cold case radiator in it and it never got over 190 on my trip to Tennessee I wanted it for towing and will come in handy when I install the AC
#4943 |
![]() Join Date: Aug 2013
Got these back from Mike at brakeboosters.com, very pleased with the work!
#4944 |
Replaced the 2nd gear servo in my 700r4 with the "Corvette" upgrade. The goal was to tighten up the 1-2 shift. Once removed, the size of the opening in the divider ring at about 2.3 inches revealed that the one installed was not the weakest servo (4-cyl, v6) but the second weakest (v6-v8) of the stock GM servos. I purchased just the upgrade kit and so had to disassemble and reassemble replacing the divider ring and its mate with the parts from the kit. Best 27 dollars I've spent on the truck! No other bang for the buck will come close to this. Holy Bjeezus man this thing shifts so much more to my liking now. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#4945 |
Got the bed covered up.
Extang Trifecta 2.0 Tri-Fold Tonneau
#4946 |
![]() ![]() Join Date: Jul 2002
Nice!
#4947 |
Thanks Bill, really happy with the fit.
#4948 |
BlahBlahBlah
That does look nice. Looks like it goes all the way to the edge of the flat section covering up stake pocket holes. So many dont.
#4949 |
Thanks Mark. I was concerned about the dimensions and fit because it is listed for a square body 1973 to 1986 truck.
I asked the manufacturer for specific dimensions and they wouldnt/couldnt offer any. ![]() ![]() I wanted to cover the stake pockets and was told it did. This fits our year trucks great width and length wise. ![]()
#4950 | |
I think I might have to get me one of these
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
