View Poll Results: To swap or not to swap? | |||
Keep plugging along... |
2 | 22.22% |
Swap that thing out! |
7 | 77.78% |
Voters: 9. You may not vote on this poll |
Ok, I'm having straight forward decision making "funk" for lack of a better term. I need you all to help. Not so short back story: I've got a 1971 GMC K2500/flatbed, with a 350/ TH350/ NP205, Dana 70 dually rear-end, Dana 44 front 4.10 gears( Un-confirmed, that is what the "tag" on both axles says). I've already done a complete tune up(plugs, wires, cap, rotor, new HEI innerds, including weights and springs) rebuilt the Edelbrock 1406 that came with it and completely rebuilt the fuel system(tank, sending unit, fuel filter, fuel pump, fuel line to the carb) I've also replaced the starter and flex plate (both were missing teeth).I've also replaced mounts/lights/ and other aesthetic parts. .. At this point I'm getting frustrated... It will not time correctly or run smooth. I've tried finding TDC using a piston stop and it is way off(yes I rotated it by hand both directions and then found the middle) it will not stay "timed" I set it 12 dgrs advanced, shut of the truck, come back 10 mins later and it is "out" by 2 dgrs(either direction). There is also noticeable slop when turning the crank by hand to when the rotor actually starts turning. This to me tells me my chain/gears are toast and at some point I've developed a tick/tap in the driver's side of the engine that sound suspiciously like a lifter/valve/rocker or similar on #7.
**At this point I'm at a cross-roads.** 1) Do I continue to patch this possibly original ( I think the heads were replaced at some point) 53 year old engine "because it runs"? OR 2) Swap in a Factory GM long block "TBI" 350 crate motor that has been sitting in the crate since 2017? Any and all advice is welcome/appreciated. |
![]() Join Date: Dec 2009
Re: Mental help needed, please.
I would say swap it out.
You will be time and money ahead.
This is actually the direction I'm leaning. I feel like I just need more experienced opinions than my own... Or put another way, "I value others (with more experience in this type of matter) opinions."
Swap it and get it on the road to enjoy. If it is the original engine you will still have it and you can take your time tearing it down and really seeing what you have.
Valid point, thank you. I could tear it down and take my time rebuilding it the way I want for long term replacement... My wife is gonna laugh at me... I swore "no leftovers"
Tell us more about this tbi crate motor.
What’s the specs on it? I’d keep plugging along. You’ve got a running motor to learn stuff from. |
Crate motor. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: Apr 2013
This ^^^^^^^^^^^^^^
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
![]() Join Date: Feb 2002
You already have a Crate Motor. Use it.
![]() Join Date: Jun 2022
It's your hobby. Spend your time, money and mental energy(aka "spoons") where you find them to be rewarding
1970 C10 Custom longbed 350/350 |
Born Psycho
![]() Join Date: Feb 2001
since the truck isn't original and unmolested I say do the crate motor and be driving it in a day or so. save your old one and build it up as time and $$$$ allow.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Born Psycho
It is a standard 350 crate motor (long block) from GM "designed for 87-95 TBI Gen 1 vehicles" which I think just means it is a standard 350 with TBI heads.
