Old 09-17-2024, 06:24 PM   #1
Rick Bollinger
67-68 E brake bracket rubber pads
Need some info on the rubber pads for the bracket that holds the emergency brake handle. Mine only has one of the square pads but there are two square holes for the pads. I didn't see anything in the search or on the LMC website. I assume it takes two not one. If someone could confirm this and point me in a direction to find them. It is about 3/4" square and about 1/2" high roughly without measuring.
Rick
Rick Bollinger is offline   Reply With Quote
Old 09-18-2024, 08:50 PM   #2
Rick Bollinger
Re: 67-68 E brake bracket rubber pads
Bump, 81 views and no responses. I could really use some help on this.
Old 09-18-2024, 09:33 PM   #3
Rick Bollinger
I got some pictures to clarify.
Old 09-18-2024, 09:36 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
The pads are bumpers for the clutch and brake pedals. If your truck is a manual it will have two of them. if it is automatic it will only have one.
https://classicparts.com/60-74-clutch-pedal-bumper
Leon
Old 09-18-2024, 09:52 PM   #5
Rick Bollinger
Sweet didn't even think about that. The truck is torn down and the cab is at the painters. Should be done in the next couple of weeks so I have been blasting and powder coating the smalls. Makes sense why there was only one and couldn't find anything under emergency brake.
Thanks BIG help.
Rick
Old 09-18-2024, 10:07 PM   #6
LockDoc
LockDoc's Avatar
Thanks BIG help.
Rick
No problem.
Leon
Old 09-18-2024, 11:14 PM   #7
Getter-Done
Getter-Done's Avatar
Great Information.
The early bird gets the worm,
85 Chevy K-20
Old 09-28-2024, 03:05 PM   #8
Rick Bollinger
Ok I received the new bumper but all I can find for fitment on my 68 is part # RP 30-C. It is only about 1/2 the height of what was on it. Other than the brake pedal being higher is there other issues that it will cause? The master and everything is still out of the cab so the brake rod will have to be adjusted to it. Can someone get a measurement on there's
to verify the height?
Rick
