Old 09-17-2024, 04:59 PM   #51
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Great, I'm glad you got it.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 09-17-2024, 05:28 PM   #52
loudchevy
loudchevy's Avatar
Round/32 spline/NP205 is a good find. Twin sticks are fun too. The front output looks like a newer seal, maybe it was recently went through when it was converted to twins.
Either way, Nice score!
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 09-17-2024, 05:31 PM   #53
pjmoreland
pjmoreland's Avatar
I am hopeful about that newer seal. We shall see...
pjmoreland is offline   Reply With Quote
Old 09-28-2024, 09:57 PM   #54
pjmoreland
pjmoreland's Avatar
Removed the front and rear bumpers today, along with the PTO winch. The rear bumper was welded directly to the frame, so I started by cutting the "brackets" in half to get the bumper out of the way. There were two sections of rail road track sandwiched between the bumper and the rear crossmember. I then cut the bracket welds most of the way through and then pounded on the bracket with a sledge until the welds cracked. I then ground some of the welds smooth. The others will have to wait until I remove the leaf spring brackets to put them back in their original places.
Old 09-28-2024, 10:01 PM   #55
pjmoreland
pjmoreland's Avatar
Front bumper and winch removal photos
I acquired a replacement radiator support since the original one was notched for the winch and it has angle iron welded all over it.
I also acquired a 4WD fan shroud.
Old 09-29-2024, 04:28 PM   #56
Ol Blue K20
You're having some good luck finding parts.
Dale
Old 09-29-2024, 08:59 PM   #57
pjmoreland
pjmoreland's Avatar
It is surprising how easy it is to find these parts considering how old they are.
Old 09-29-2024, 09:03 PM   #58
pjmoreland
pjmoreland's Avatar
Removed the rear end today, and freed one shackle bracket from the funky lift. Used a cutoff wheel and a Dremel to cut the welds. I still need to clean up the frame and brackets. I've got five brackets left. It's gonna take me a couple more weekends to finish this.
Old 10-01-2024, 09:20 AM   #59
57taskforce
All about them K’s
57taskforce's Avatar
Nice work!!! The rear bumper on my K20 was welded to the frame as well. I feel your pain, it can be a real blast dealing with PO shenanigans.
Tyler
Old 10-01-2024, 11:38 AM   #60
pjmoreland
pjmoreland's Avatar
It's a real mess. I'm looking forward to having this stage behind me.
Old 10-01-2024, 12:25 PM   #61
clay68c10
clay68c10's Avatar
Nice work, you took off a lot of weight removing those bumpers.
Cool find with those pieces of track. They make great little anvils.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 10-01-2024, 12:53 PM   #62
pjmoreland
pjmoreland's Avatar
I will definitely be keeping them for that purpose!
Old 10-02-2024, 01:25 AM   #63
pjmoreland
pjmoreland's Avatar
Removed two more leaf spring brackets today. Three more to go. That forward bracket was a real challenge to remove since it is large and had lots of welds all over it.
Old 10-02-2024, 10:04 PM   #64
pjmoreland
pjmoreland's Avatar
Finished removing the remnants of the box tubing on the big bracket I removed yesterday. Started working on the last of the four brackets, but it defeated me for now. Ran out of Dremel discs. Ordered some a few days ago, but they won't be here until tomorrow. Didn't feel like spending $18 for another 5 locally.
Old 10-03-2024, 04:18 PM   #65
Ol Blue K20
You're getting some work done! Nice job.
Dale
Old 10-03-2024, 06:29 PM   #66
57taskforce
All about them K’s
Man that’s a lot of work. You’re doing great! Who ever did all this would have been time majorly ahead to just buy some lift springs. That was one big cobbled up mess.
Tyler
Old 10-03-2024, 10:47 PM   #67
pjmoreland
pjmoreland's Avatar
It was a fight, but that fourth rear leaf spring bracket is off. I put a couple little gouges in the frame that I'll have to weld up.
Old 10-04-2024, 09:55 PM   #68
pjmoreland
pjmoreland's Avatar
Cleaned up the rear frame rails.
Old 10-05-2024, 04:59 AM   #69
Ol Blue K20
Nice, it.will beback on springs soon
Dale
Old 10-05-2024, 10:54 PM   #70
pjmoreland
pjmoreland's Avatar
Repaired the gouges in the leaf spring brackets by filling them with weld and grinding them smooth. Painted and reinstalled the brackets. The PO had put the forward brackets on the wrong sides. Reinstalled the rear end. The truck is back on its rear wheels. It was a long day. I am beat!
Old 10-05-2024, 10:56 PM   #71
pjmoreland
pjmoreland's Avatar
A few more photos
Old 10-06-2024, 10:12 PM   #72
pjmoreland
pjmoreland's Avatar
Removed the front leaf spring brackets and cleaned up the frame. Welded up a couple of cracks in the front bumper area of the frame. I still need to detach the box tubing "lifts" from the brackets.
Old 10-07-2024, 01:17 PM   #73
Ol Blue K20
It's looking good.
Dale
Old 10-09-2024, 12:15 AM   #74
pjmoreland
pjmoreland's Avatar
Removed the box tubing from the front leaf spring brackets, cleaned them up and painted them.
Old 10-10-2024, 11:36 PM   #75
pjmoreland
pjmoreland's Avatar
Reinstalled the front leaf springs in their correct locations and replaced the home-made shackles with stock units. The truck is still sitting pretty high. The next project is to remove the body lift spacers and install new body bushings.
