Old 10-12-2024, 11:24 PM   #11
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
I also removed the 3" body lift and installed new cab mounts and radiator support mounts. When I went to remove the custom long steering intermediate shaft, I discovered that it had been welded to the steering gearbox, and the gearbox shaft had its splines ground off. I was hoping I could use this gearbox, but I guess that's not happening.
The truck is finally at the final ride height other than the sag that will result from installing the engine, transmission, etc.
pjmoreland is online now   Reply With Quote
