Old 10-23-2024, 06:08 PM   #126
nicklear36
nicklear36's Avatar
Re: 1970 C10 ChassisFab Build Thread
Originally Posted by raggedjim View Post
Nice work on this truck! What did you use to paint the engine? Did you use a clearcoat?
Rg
2K spraymax clear cans and chevy orange VHT basecoat. We'll see how it holds up
nicklear36 is offline   Reply With Quote
Old 10-23-2024, 06:22 PM   #127
nicklear36
nicklear36's Avatar
Originally Posted by zicc1835 View Post
can you tell me who's AC kit your using my cab is a non AC cab Im going to convert ..I converted and used Vintage in my Cheyenne( was a factory AC cab) years ago but their kits are Gens ahead now from when I installed mine ....looking at the condenser install looks clean
I pieced together a DIY kit on this to save some money.
It is a Vintage Air Gen II evaporator: https://www.amazon.com/gp/product/B0...ustomerReviews
Hose kit: https://www.ebay.com/itm/20223073898...Bk9SR5CZirfXZA
Universal condenser: https://www.ebay.com/itm/305517518009
It's a little flimsy so I will be adding another universal bracket to attach to the core support.
Sanden compressor: https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Old 10-24-2024, 09:43 AM   #128
raggedjim
raggedjim's Avatar
Thanks, it really looks good.
raggedjim is offline   Reply With Quote
Old 10-24-2024, 08:51 PM   #129
zicc1835
zicc1835's Avatar
Like the approach you have taken on this and thank you for taking the time to share
this is very much appreciated im going to follow your lead on this and pick your brain on a couple things in a PM before I order
zicc1835 is offline   Reply With Quote
Old 03-17-2025, 03:02 PM   #130
Basketcase889
Basketcase889's Avatar
Any updates?
1970 - Green LWB C10 - 250 I6/3OTT
1969 - Blue/White LWB C10 CST - 350/TH400
1950 - Original Patina 3600/S10
Basketcase889 is offline   Reply With Quote
Old 03-26-2025, 05:21 PM   #131
nicklear36
nicklear36's Avatar
Sorry for not many updates. The entire truck has been media blasted, and I am continuing on with cab rust repair.
This is the Vannatta 5-piece firewall kit all welded up. I'm really liking the bead roll pattern on it.
Old 09-23-2025, 06:35 PM   #132
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I see your still plugging along.Looks great
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-10-2025, 05:54 PM   #133
nicklear36
nicklear36's Avatar
Photo dump
Old 11-10-2025, 08:02 PM   #134
zicc1835
zicc1835's Avatar
nice progress......
Old 01-28-2026, 02:29 PM   #135
nicklear36
nicklear36's Avatar
Tinted Raptor liner applied to the bottom of the cab and bed.
Old 01-28-2026, 07:01 PM   #136
raggedjim
raggedjim's Avatar
Yeah, that looks good!
Old 02-02-2026, 03:21 PM   #137
rodstored-72
chevy truck fan
rodstored-72's Avatar
nick, nice job on the liner for the bottom of the bed. wondering what you did as far as prep & cleaning before you sprayed? I am fixing to do the inside bed on my 1986 C10 & just wanted to get info. from real world experience. thanks!! I know a lot of YT videos and such.. just wanted to see what you did...
rodstored-72 is offline   Reply With Quote
Old 02-03-2026, 01:29 AM   #138
nicklear36
nicklear36's Avatar
Thank you mate I appreciate it. I ended up getting the whole truck sandblasted for around 3k here in Oregon. It was a tough pill to swallow but having all of the metal ready for epoxy primer and then paint saved so much time.
If that's not in the budget a wire wheel and 80 grit sandpaper would also do just fine. That's how I did my frame.
Old 02-09-2026, 01:09 PM   #139
rodstored-72
chevy truck fan
nick, thanks for the reply... i figured the latter recommendation would be the "go to" i am planning on the 80/120 grit followed by red scuff pad & then do the liner.... any bare spots i will prime beforehand.....
thanks for the reply!! continue the good work!!
Old 02-19-2026, 10:11 AM   #140
PowerdbyChevy79
PowerdbyChevy79's Avatar
Looking good
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
