Old 10-28-2024, 01:50 AM   #126
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Reassembly
pjmoreland is offline   Reply With Quote
Old 10-28-2024, 01:51 AM   #127
pjmoreland
pjmoreland's Avatar
Setup
Old 10-28-2024, 01:53 AM   #128
pjmoreland
pjmoreland's Avatar
I also reinstalled the sender with a new Jeep plastic float and a new seal.
Old 10-28-2024, 04:14 AM   #129
bobbylong
Nice truck, I love it! I'll follow your thread as I work on my '71 step-side.
Bobby
1971 K10 SWB Stepside
1968 Chevy Camaro
1931 Ford Model A (truck)
1997 Land Rover Defender 90
1994 Harly Davidson MT350
bobbylong is offline   Reply With Quote
Old 10-28-2024, 09:23 AM   #130
loudchevy
loudchevy's Avatar
Originally Posted by pjmoreland View Post
Someone did some crazy shimming on this axle at some point. The pinion and carrier shims were mangled. It appears that they enlarged the bearing IDs so that they'd be a slip fit.
Maybe the same someone that welded all the things on the rest of the truck
Great progress.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 10-28-2024, 10:48 AM   #131
pjmoreland
pjmoreland's Avatar
Great progress.
I think you might be onto something there
Old 10-28-2024, 10:49 AM   #132
pjmoreland
pjmoreland's Avatar
Nice! There aren't too many of these out there.
Old 10-30-2024, 01:09 AM   #133
pjmoreland
pjmoreland's Avatar
This evening I worked on getting the pinion depth and preload set. I settled on .035" on the pinion which is only .002" less than the funky trashed shims that were in there. The drive side would have been better with a thinner shim, but the coast side would be way on the edge of the tooth that way. It feels smooth when rotated.
I installed a solid sleeve on the pinion and got the preload in spec. Took a couple of hours to get it right, but now I will be able to take it apart and put it back together in the future without worrying about messing up a crush sleeve.
I cleaned up and painted the pinion yoke, so installation will have to wait until the paint dries. This is a nice original yoke I had left over from another project. The one that was on this truck had messed up splines and was loose on the pinion. The pinion splines look perfectly fine, and this other yoke fits nice and snugly.
I wouldn't be surprised if the issues with this rear end were what doomed this truck in 2001.
Old 11-01-2024, 02:52 AM   #134
pjmoreland
pjmoreland's Avatar
Finished setting up the rear end this evening. Got the backlash set at .008" and the carrier bearings are preloaded.
One of the axle shafts was the wrong length so a brake drum wouldn't fit (it would hit the backing plate). I replaced it with a new axle shaft that's the correct length. Installed new studs on both sides and painted the axle flanges.
Cleaned up the diff cover. It had a few small dents and the bottom edge was bent up from being hit with jacks over the years. Straightened it out a bit and then painted it black.
Old 11-01-2024, 02:53 AM   #135
pjmoreland
pjmoreland's Avatar
More photos
Old 11-01-2024, 02:57 AM   #136
pjmoreland
pjmoreland's Avatar
Diff cover photos
Old 11-01-2024, 07:50 AM   #137
1970cstblazer
1970cstblazer's Avatar
As always, beautiful workmanship.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 11-01-2024, 10:46 AM   #138
pjmoreland
pjmoreland's Avatar
Thank you
Old 11-02-2024, 12:29 AM   #139
pjmoreland
pjmoreland's Avatar
Put some gear oil on the internals to help keep rust at bay. I will fill it after I weld on new perches. Installed the cover.
Old 11-02-2024, 08:55 AM   #140
57taskforce
All about them K’s
57taskforce's Avatar
Excellent work!!
Tyler
Old 11-02-2024, 09:04 AM   #141
pjmoreland
pjmoreland's Avatar
Originally Posted by 57taskforce View Post
Excellent work!!
I appreciate it. I wish I had more time to work on this truck.
Old 11-02-2024, 10:54 AM   #142
57taskforce
All about them K’s
Man that’s always how it is, time and money. Rarely do you ever have sufficient of both. You’re doing a great job so far. This thing has turned around in a huge way in not that much time! A lot of these trucks would be lucky to have more owners like you!
Tyler
Old 11-02-2024, 09:16 PM   #143
D.B
D.B's Avatar
Great job, slowly but surely you will have back on the road before you know it. Then all of the hard work will be a distant memory. Keep it up!!
Darrell
1972 Cheyenne Super C20 (My Fun Drive)
2000 S10 Xtreme (My Drag Truck)
D.B is offline   Reply With Quote
Old 11-02-2024, 11:25 PM   #144
pjmoreland
pjmoreland's Avatar
Thank you, Darrell. I'll keep plugging away at it! I'm actually really enjoying the project.
Old 11-02-2024, 11:28 PM   #145
pjmoreland
pjmoreland's Avatar
More axle work today. Removed the bent rear perches in preparation for replacing them. Used a large drill bit through the center hole to mark the location of each perch on the axle.
Old 11-02-2024, 11:33 PM   #146
pjmoreland
pjmoreland's Avatar
Replaced the front axle u-joints. They were really stuck in there. Took lots of pressing back and forth on both sides to get them to break free. Cleaned them up with a wire wheel and painted them
Old 11-02-2024, 11:35 PM   #147
pjmoreland
pjmoreland's Avatar
Reassembly
Old 11-02-2024, 11:38 PM   #148
pjmoreland
pjmoreland's Avatar
Also pulled the front carrier and pinion bearings. Assembled a puller from various tools.
Old 11-04-2024, 02:43 PM   #149
pjmoreland
pjmoreland's Avatar
Did some rust removal on the portion of the front diff carrier that was not submerged in oil. It's badly pitted, but thankfully none of the machined surfaces or gears are rusted.
Old 11-04-2024, 10:46 PM   #150
pjmoreland
pjmoreland's Avatar
Welded new perches onto the rear axle this evening. Decided to set them at the stock angle since my suspension is at stock height.
