Old 11-13-2024, 08:59 AM   #176
loudchevy
loudchevy's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
I love the consistent progress! What's next on the list to tackle?
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 11-13-2024, 10:42 AM   #177
pjmoreland
pjmoreland's Avatar
Originally Posted by CUSTOM/10 View Post
Those shims are a PITA... I honed out a set of bearings & races to a slip fit to mock-up the gear pattern. I was changing the gear ratio so the shims were totally different. It was still a PITA.
Good looking work.
Gary
Good call on the honed out bearings. That may be in my future if the front or rear gears are noisy.
I was under the impression that the gears in my truck were the original gears since 3.73 was standard equipment, and the SPID doesn't list the ratio. I was reading the optional equipment list in the sales brochure for 1971, and it says a 350 engine gets 3.07 gears. My SPID lists a 350 engine. It is obvious that someone has worked on both the front and rear gears on this truck, so it was probably to swap the original 3.07 gears for 3.73 gears.
pjmoreland is online now   Reply With Quote
Old 11-13-2024, 05:28 PM   #178
'68OrangeSunshine
'68OrangeSunshine's Avatar
I'm not claiming to be a total expert, Pat, but from what I've gathered; the 3.73 Ratio was standard for Manual Transmission trucks, while the 3.07 was for Automatic Transmissions.
Old 11-13-2024, 05:45 PM   #179
pjmoreland
pjmoreland's Avatar
Hmm. My SPID lists a 350 engine and a 4-speed transmission. Here's the table from the 1971 sales brochure that had me wondering about the gears. The brochure also says that 3.07 will be included with a 350 engine.
Old 11-13-2024, 06:49 PM   #180
'68OrangeSunshine
OK. IDK.
My '71 GMC Jimmy K/1500 was originally equipped with V8 350/SM465/NP205/ 3.73 w/Posi.
I have a 1972 Chevy K/5 Blazer Tub/Chassis out the 'Back Forty'. While it has no Engine, Transmission, or Transfer Case, and no Glove Box Door [ergo, no SPID], the Rear Differential was a 3.07 when I opened it up and counted teeth. This Blazer was originally an Auto Tranny truck.
Flint build.
Old 11-13-2024, 06:51 PM   #181
pjmoreland
pjmoreland's Avatar
OK. IDK.
Flint build.
Does your '71 Jimmy still have the SPID, and does it list 3.73?
Old 11-13-2024, 07:07 PM   #182
'68OrangeSunshine
Yes it does. OK. I get it. The Original Buyer _opted_ for 3.73 in his differentials.
Since White Fang and 919 both were 3.73 trucks, I made the assumption 3.73 was always STD.
Old 11-13-2024, 07:24 PM   #183
pjmoreland
pjmoreland's Avatar
That makes sense.
The funky shims in my rear diff, and new bearings in the front diff point to a gear swap.
Old Yesterday, 02:15 AM   #184
pjmoreland
pjmoreland's Avatar
I wish my SPID were as clean as yours. Mine has been exposed to the weather for who knows how long because the windshield was missing.
Old Yesterday, 06:02 PM   #185
'68OrangeSunshine
It is surprizingly clean. The paint shop that shot Maui Blue over the Factory 522 Medium Bronze took pains to mask over the SPID. I think the PO's FIL owned the shop and the blue paint job was a wedding present. They were from LA. [Venice Beach, and their PO was in Newport.]
As an inner-city security feature, the Door Lock Knobs and relay rods had been deleted. The doors were kept locked and when picking up the spouse, she/he had to user their key to open the door, they told me.
About 4 or 5 years later I made a road trip up to the Bay Area, and Jerry Moss gave me a pair of Relay Rods, when I bought a Blazer Windshield Frame from him.
Old Today, 01:33 AM   #186
pjmoreland
pjmoreland's Avatar
I finished a batch of dummy filler necks two days ago and had some two part epoxy paint and primer left over that needed to be used up. This evening I cleaned up the front brake caliper brackets/dust shields, some little parking brake parts and some original stepside rear bumper gravel shields and painted them.
Old Today, 07:46 AM   #187
CUSTOM/10
CUSTOM/10's Avatar
It's hard to find those dust shields still intact. Yours look solid, there usually rusted away or damaged.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old Today, 11:04 AM   #188
pjmoreland
pjmoreland's Avatar
Gary
I straightened out a couple of bent corners on them, and one appears to have detached partially from the caliper bracket at some point and got welded back on. The metal is still thick and solid though. I noticed that the single mounting screw for each dust shield is missing.
Old Today, 12:27 PM   #189
CUSTOM/10
CUSTOM/10's Avatar
If the threaded hole in the knuckles isn't there, then I would suspect either the knuckles or front axle have been changed at some point. You could look up the axle numbers.
My dust shields were in about the same shape.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old Today, 01:25 PM   #190
pjmoreland
pjmoreland's Avatar
Gary
The threaded holes are there, and thankfully there aren't snapped off bolts in them, which is what I was half expecting to find.
Old Today, 01:43 PM   #191
pjmoreland
pjmoreland's Avatar
The truck should be down off of jack stands soon.
