#201 |
![]() Join Date: Feb 2002
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Pat, Was your '71 K/10 Stepside originally an Air Force truck? The darker metallic blue suggests that to me. But internet colors get distorted.
#202 |
![]() ![]() Join Date: Jan 2005
Unfortunately I know next to nothing about the history of this truck. The original paint was dark olive, and now it's covered in gray primer. One bed fender and the interior are still green.
#203 | |
And the Air Force never ''borrows'' trucks from the Army. [Only the Marine Corps has a 'tradition' of assimilating vehicles from other branches -- usually when they ain't looking.]
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 11-17-2024 at 06:10 AM. |
#204 | |
#205 |
I disassembled the front hubs today with the intention of replacing the bearings and seals. Unfortunately, one of the hubs needs to be replaced because at some point a bearing spun in it and wore a groove. I have a lead on a replacement.
I did go ahead with installation of the axle shafts, spindles and dust shields. I also installed new axle vent hoses and vent caps. Filled the differentials with fluid. Also worked on a large crease in the passenger side front fender and adjusted the hood so that it latches now. |
#206 |
Here's the hub that got damaged by a spun bearing.
#207 |
More photos
#208 |
![]() Join Date: May 2003
Hey Patrick, there are 2 different style hubs & spindles . Large bearing and small bearing. I believe yours look to be small bearing. You can use either but they have to be used as pairs, ( spindle & hub ) both large or both small. The outer bearings are the same, the inner bearing ( the one you spun ) is the difference. So keep that in mind when your sourcing parts.
If you run into trouble l have some small bearing hubs & spindles. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 11-17-2024 at 10:35 AM. |
#209 | |
#210 |
The spindle measures 1.779" at the inner bearing location.
The inner bearing O.D. is 3.063". |
#211 |
![]() ![]() Join Date: Jul 2003
Here is info right from the parts book:
Note: 1971 & 1972 would be the same as 1973-77 1st design.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#212 |
#213 |
Go by the measurements, you never know what may have been swapped in there by a previous owner. I have also seen left over prior year parts use on the next year.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#214 |
1970cstblazer is correct on the bearing years, it was the axle shaft size that changed in 72.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 11-17-2024 at 03:38 PM. |
#215 |
Did some rust repair on the passenger side inner fender. The driver side inner fender had been mutilated to make room for the misaligned steering column because of the body lift, so I bought a replacement for that side. I chopped a piece off of the mutilated one and welded it into the passenger side. It isn't pretty, but it is functional, and it will be hidden behind the battery.
#216 |
Nice save!
#217 | |
#218 |
#219 | |
I would trust GM's guidance on this versus Moog. Moog USED to be the gold standard of the aftermarket suspension parts realm, but I have experienced some QC issues with their parts and therefore refuse to use them. This is why I spent the longer dollar on all NOS GM suspension parts for the Blazer. The fit and metallurgy are known and proven. Case in point, the original ball joints and tie rod ends on my 70 Blazer were still tight after 53 years and 93k miles of borderline abuse. Unfortunately, they suffered pitting and corrosion, making them look like crap. Mom and dad have lived on the same substandard dirt roads since 1970, so it had to endure all of that.
#220 |
I got up at 4am this morning and spent a total of about six hours driving today, so I felt like just sitting around when I got home. I wanted to get at least some time in on the truck though, so I wire wheeled the inner fender and painted it. I sprayed the bottom of it with rubberized undercoating.
#221 | |
#222 |
#223 |
I measured the thickness of my rotors. One measures 1.250 and the other measures 1.230. Seems odd that they are that much different. Anyway, the minimum is 1.215, and new they were 1.285, so one is down to 50% and the other is at 21%. I'm just going to replace both of the rotors. I pressed out the studs and freed my one good hub from the rotor. I should be getting the replacement hub for the other side early next week.
#224 |
When I replaced the rotors on my 1970, I was able to source the 12 studs on Ebay. I did not want to use the currently available Dorman pieces.
Raysbestos 5020b, GM 3995841, Wagner BD60908
#225 |
Thank you for the part numbers. I ordered 12 of the Wagner units off eBay. The studs I removed are all slightly tweaked from being pressed out, so they definitely need to be replaced.
| Bookmarks |
