Yesterday, 07:11 PM | #201 |
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Pat, Was your '71 K/10 Stepside originally an Air Force truck? The darker metallic blue suggests that to me. But internet colors get distorted.
Yesterday, 07:14 PM | #202 |
Unfortunately I know next to nothing about the history of this truck. The original paint was dark olive, and now it's covered in gray primer. One bed fender and the interior are still green.
Yesterday, 07:24 PM | #203 | |
And the Air Force never ''borrows'' trucks from the Army. [Only the Marine Corps has a 'tradition' of assimilating vehicles from other branches -- usually when they ain't looking.]
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; Today at 06:10 AM. |
Today, 12:51 AM | #204 | |
Today, 01:05 AM | #205 |
I disassembled the front hubs today with the intention of replacing the bearings and seals. Unfortunately, one of the hubs needs to be replaced because at some point a bearing spun in it and wore a groove. I have a lead on a replacement.
I did go ahead with installation of the axle shafts, spindles and dust shields. I also installed new axle vent hoses and vent caps. Filled the differentials with fluid. Also worked on a large crease in the passenger side front fender and adjusted the hood so that it latches now. |
Today, 01:18 AM | #206 |
Here's the hub that got damaged by a spun bearing.
Today, 01:23 AM | #207 |
More photos
Today, 07:51 AM | #208 |
Hey Patrick, there are 2 different style hubs & spindles . Large bearing and small bearing. I believe yours look to be small bearing. You can use either but they have to be used as pairs, ( spindle & hub ) both large or both small. The outer bearings are the same, the inner bearing ( the one you spun ) is the difference. So keep that in mind when your sourcing parts.
If you run into trouble l have some small bearing hubs & spindles. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; Today at 10:35 AM. |
Today, 11:45 AM | #209 | |
Today, 01:08 PM | #210 |
The spindle measures 1.779" at the inner bearing location.
The inner bearing O.D. is 3.063". |
Today, 01:29 PM | #211 |
Here is info right from the parts book:
Note: 1971 & 1972 would be the same as 1973-77 1st design.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Today, 01:33 PM | #212 |
Today, 02:35 PM | #213 |
Go by the measurements, you never know what may have been swapped in there by a previous owner. I have also seen left over prior year parts use on the next year.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Today, 03:16 PM | #214 |
1970cstblazer is correct on the bearing years, it was the axle shaft size that changed in 72.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; Today at 03:38 PM. |
Today, 09:44 PM | #215 |
Did some rust repair on the passenger side inner fender. The driver side inner fender had been mutilated to make room for the misaligned steering column because of the body lift, so I bought a replacement for that side. I chopped a piece off of the mutilated one and welded it into the passenger side. It isn't pretty, but it is functional, and it will be hidden behind the battery.
Today, 09:50 PM | #216 |
Nice save!
