Old 10-31-2024, 07:13 PM   #1
dave6672
dave6672's Avatar
Question about 67 SWB frame
I bought this 67 about two years ago and am just now working on it. I noticed a number stamped on the frame that clearly appears to have a 1979 date. This stamp is located on the side of the frame right under the driver’s door. Does anybody recognize this type of stamp in this area? I’m not familiar with square body frames so could the truck have been framed swapped years ago with a 1979 frame?
Both of my 72’s have the VIN stamped on the frame of the driver’s side near the steering box. Did 67’s have the VIN stamped there as well? Mine has nothing stamped in that location.
My VIN number on door jam plate and SPID match each other and the truck’s options match the SPID. However the VIN plate does not have rosette rivets. Did 67 models use those? Just curious.
Thanks for all input!
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
dave6672 is offline   Reply With Quote
Old 10-31-2024, 07:33 PM   #2
Rods
Rods's Avatar
Re: Question about 67 SWB frame
part number for frame rail
some did some didn't has been my experience
yes they did have rosette rivets
Az
Rods is offline   Reply With Quote
Old 10-31-2024, 07:46 PM   #3
chewychevy67
Yep my 67 has no vin frame stampings either. But It does have numbers like your pictures on the side of the frame too. That's a nice little truck. It's possible someone painted it and removed the plate although it looks pretty original.
chewychevy67 is offline   Reply With Quote
Old 10-31-2024, 08:01 PM   #4
weq92f
weq92f's Avatar
Sweet '67 you got there. More pics in the future mehopes!
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 11-02-2024, 05:41 PM   #5
cbeerman
I'm also curious about frame documentation. I was able to find this information although it doesn't prove anything it may help you feel better about your frame.
GM Parts Wiki has a listing for 3887701 in the Parts History Catalog P&A 30H January 1973
http://www.gmpartswiki.com/getpage?pageid=68721
http://www.gmpartswiki.com/getpage?pageid=68913
3887701 USE 03913179 11-67
Part number 3887701 was substituted by 3913179 in Nov of 1967
Check out these threads
https://67-72chevytrucks.com/vboard/...d.php?t=219669
https://www.67-72chevytrucks.com/vbo...d.php?t=810797
so 10-7-79 is some type of manufacturing code and not a date
Hopefully someone more knowledgeable will chime in
cbeerman is offline   Reply With Quote
Old 11-02-2024, 06:27 PM   #6
cbeerman
Going further down the rabbit hole
3887702 USE 03913180 04-67
http://www.gmpartswiki.com/getpage?pageid=68743
3913179 USE 03935801 03-68
3913180 USE 03935802 03-68
http://www.gmpartswiki.com/getpage?pageid=221072
3935801 68-70 Ser. 10 W/115 WB (exc. 4/WD leaf spring) Left
3935802 68-70 Ser. 10 W/115 WB (exc. 4/WD leaf spring) Right
So it looks like part number 3887701 is for a 1967 C10, short bed, coil spring, driver's side (Left) frame rail.
Old 11-02-2024, 09:51 PM   #7
dave6672
dave6672's Avatar
Thanks for the responses and this information, cbeerman. It has been very helpful. I guess the number on my frame that looks like a date on my frame is actually some other part number of sorts.
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
Old 11-17-2024, 12:51 PM   #8
WorldsCrappiestTruck
Junior Member
Adding some questionably helpful into here? I just got to stripping the frame of my ‘67 GMC 2WD short fleet and have these markings I came across.
DRIVERS
3914401-310
3-30-110
PASSENGERS
3914402-310
4-4-110
VIN tag has rosette rivets, has CS1570D on the VIN tag, CS1570-120 on the cowl, CS1570 on the inside of the drivers frame rail…..then a bunch of 507, 495, 1116 markings on the firewall. No idea what these mean.
There is also something cryptic on the inside of the drivers frame rail.
No VIN stamp on the frame anywhere unfortunately - causing me a hang of a time with the local regulators on having a VIN verification done. They’re adamant they need to see the VIN in 2 spots. All I have is the door. No SPID, no frame stamp like my ‘68 proudly shows.
I hope something is helpful here??
WorldsCrappiestTruck is online now   Reply With Quote
Old 11-17-2024, 12:53 PM   #9
Junior Member
More
Old 11-17-2024, 04:09 PM   #10
67swb72klb
67swb72klb's Avatar
Nice truck!
Never heard this before I will have to check my frame for the VIN #
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 11-17-2024, 06:07 PM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
DRIVERS
3914401-310
3-30-110
PASSENGERS
3914402-310
4-4-110
And I thought Vermont was the state everybody used to get easy registration when there is no valid title?
I can't say if your local motor vehicle bureaucracy would buy it, if you had a fresh SPID printed and mounted on the glove box lid. But there are artisans who can print fresh SPIDs. That would be your two forms of ID.
Old 11-17-2024, 07:08 PM   #12
dave6672
dave6672's Avatar
Here is a link to Jeff at Out in the Shop. He can reproduce a SPID if you need it
https://outintheshop.com/
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
Old 11-18-2024, 09:19 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
The ID is stamped in several places on your truck. If these sharpers are so smart, they know where those places are and can check them. Pretty sure there's one on the firewall at the heater box. Law enforcement has the particulars, for obvious reasons.
~Steven
Simi Valley, CA
Old 11-18-2024, 11:21 PM   #14
Junior Member
Thanks Dave - will check it out.
Fake News? I haven’t read of any other place on these trucks you’ll find a vin except the SPID, the door jamb, the frame, and maybe just maybe a build sheet stuffed in the seat?
New cars are stamped on damn near every panel. I took my ‘68 apart down to every last nut & bolt, and the only location was the door jamb and 2x on the drivers frame rail. SPID had been removed and there was no seat.
Old Yesterday, 12:43 AM   #15
Steeveedee
Who Changed This?
Steeveedee's Avatar
Not "fake news", and I don't appreciate that accusation.
~Steven
Simi Valley, CA
Old Yesterday, 10:19 AM   #16
70STOVEBOLT
70STOVEBOLT's Avatar
Are you saying the VIN is stamped on the firewall near the heater box? I had not heard this before. I will have to look now.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old Yesterday, 12:21 PM   #17
Junior Member
Not trying to be accusational……sorry if it came off that way. This is the first I’ve heard or read that a VIN is elsewhere on our truck bodies. Could you post a pic or two for the group?
Old Yesterday, 12:42 PM   #18
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Question about 67 SWB frame
When I had my 1970 Blazer completely disassembled, I only found 5 locations on the whole truck with either full VINS or partial VINS.
They are as follows:
Main stainless steel VIN tag - Full VIN stamped
LH Door Safety standards declaration decal - Full VIN printed
Glovebox SPID decal - Full VIN printed
LH frame rail near steering gearbox and PS pump on top surface- Partial VIN stamped
LH frame rail top surface in the vicinity of where the drivers seat would be located - Partial VIN stamped
My Blazer was manufactured at the St. Louis plant.
Example of the partial VIN:
0S123456
0-Last digit of the year 1970
S- St. Louis assembly plant
123456 - VIN sequential number. Must match last six digits of VIN on tag on door jamb!
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
